Compression Issue
Old Jul 18, 2005 | 11:02 AM
icebergli's Avatar
Default Compression Issue
Hello...i have a fully built h22 using 8:5:1 pistons. I havent gonew turbo yet. Still breaking the engine in. The car has no power at all...complete slug! Wondering if I went too low on the compression or is it fine for turbo. Thanks
Old Jul 18, 2005 | 11:06 AM
11psiTurboSI's Avatar
Default Re: Compression Issue (icebergli)
Have you done a compresison test yet?
Old Jul 18, 2005 | 11:28 AM
icebergli's Avatar
Default Re: Compression Issue (11psiTurboSI)
yea....#'s are good straight across. just wanna make sure I didnt go too low with those pistons
Old Jul 18, 2005 | 11:32 AM
turbosi03's Avatar
I don't understand what your asking... is it too low because your car is now slow without boost? it should be slower with less compression on N/A motor...
8.5 is on the lower side but people run that compression with boost all the time. just use a lot of boost
Old Jul 18, 2005 | 11:55 AM
icebergli's Avatar
Default Re: Compression Issue (turbosi03)
Its a daily driver and I'm only gonna be driving around on 15psi on the street. Using a Gt35r turbo
Old Jul 18, 2005 | 12:37 PM
I run 8.8:1cr in my 81mm B16a2 and at first it felt really sluggish part throttle... Then I got it tuned by Mase and it made a world of difference. Have you gotten it tuned?
Old Jul 18, 2005 | 07:43 PM
PrettyLude's Avatar
too low imo for a daily driver, 9 to 1 is my vote
Old Jul 18, 2005 | 08:25 PM
beerbongskickass's Avatar
Default Re: (PrettyLude)
8.5:1 will be fine for a daily driver. You will be able to make a lot of power on pump gas with that compression and turbo. Get that thing tuned though asap!
99siRACER
Jan 3, 2012 12:20 AM
93delslow315
May 13, 2010 10:57 PM
slowcrx954
Nov 23, 2006 07:49 AM
MobRacing2
Feb 24, 2006 06:43 AM
s0liDyNe
Jul 19, 2003 10:24 PM
