H22 Turbo
Old Apr 21, 2006 | 06:04 PM
tcontesh's Avatar
Default H22 Turbo
I have been having the worst time ever trying to get my car tuned. Ive tried different ECU's, several Uberdata and Crome programs, a few different shops with good tuners, and noone can seem to figure it out. My setup runs fine all the way up to about 5000 rpms right where vtec is supposed to kick in, everything is perfect with a nice smooth line on the dynosheet. After 5000 rpms the lines on the map cross and jump all over the place and it looks like the worst ******* mess ever and my ignition is everywhere, as soon as they see that mess they give up and say expletive that and send me on my way. The weird thing is my car runs fine in boost, but I have no power up top and no VTEC. SOMEONE HELP.
Old Apr 22, 2006 | 02:41 PM
tcontesh's Avatar
Default Re: H22 Turbo (tcontesh)
Then has anyone had problems with h22 turbos, could you give me a list of things that you had to replace that would cause trouble shooting. THANKYOU
Old Apr 23, 2006 | 11:37 AM
Moto-C's Avatar
B A N N E D
is your sh tip tronic. also what map sensor are you using...
Old Apr 23, 2006 | 01:14 PM
swappedcivic's Avatar
Iam having the same problem right now also. vtec hits and the car falls on its face and i cant seem to figure it out
Old Apr 23, 2006 | 01:25 PM
Hybrid96EK's Avatar
My first guess would be some kind of electrical/wiring issue. You said Vtec doesn't work and also report issues with the ECU after a certain RPM. If it still does it with several ECU's and programs, you have ruled out the ECU. Its time to take a look at your wiring is my guess. Perhaps a bad ground?
Old Apr 23, 2006 | 01:30 PM
Default Re: H22 Turbo (Hybrid93Eg)
All i have used is the aem ecu. The wiring is all ok checked that a few times. Would the temp of the coolant have anything to do with it? My gauge is reading wrong but when you check the temp right next to the sensor it is fine/
Old Apr 23, 2006 | 04:56 PM
Default Re: H22 Turbo (swappedcivic)
check this thread out it might help https://honda-tech.com/zerothread?id=830163
Old Apr 23, 2006 | 06:57 PM
tcontesh's Avatar
Thanks alot for that thread.
Old Apr 23, 2006 | 07:47 PM
tcontesh's Avatar
Default Re: (Moto-C)
I have the stock map sensor, should I have an aftermarket one?
Old Apr 23, 2006 | 08:05 PM
Hybrid96EK's Avatar
Default Re: (tcontesh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tcontesh &raquo;</TD></TR><TR><TD CLASS="quote">I have the stock map sensor, should I have an aftermarket one?</TD></TR></TABLE>
for 8psi, you are fine. Anything over 11psi, you want to ditch the stock map sensor.
Old Apr 23, 2006 | 09:09 PM
safe driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swappedcivic &raquo;</TD></TR><TR><TD CLASS="quote">Iam having the same problem right now also. vtec hits and the car falls on its face and i cant seem to figure it out</TD></TR></TABLE>
hmm... what version ems cal are you using? is your ignition sync'ed? is knock control enabled? what is your afr when after the vtec crossover?
BrownProdigy
Mar 13, 2015 07:58 AM
slowem1si
Sep 21, 2006 03:29 PM
1750cc
Jun 21, 2006 06:49 PM
tcontesh
Apr 24, 2006 07:04 PM
whatVTEC
Dec 16, 2003 02:24 PM
