h22 trans and clutch
Old Apr 20, 2012 | 06:25 AM
sshh's Avatar
Default h22 trans and clutch
Ok so my trans start to tick tick on 680hp h22.
looking for new and strong trans that want brake....i tried to search but every one is complaining on the h22 trans even the build ones.
any other option?
At this opportunity i am looking for twin plate clutch, now using competition stage 5 ,does the twin plate from this company will do the job?
Thanks!
Old Apr 20, 2012 | 06:42 AM
Turbo-LS's Avatar
Default Re: h22 trans and clutch
Well at that hp level nothing Oem is going to hold up for long. If you want to continue to run big powers start saving up for a gearset
Old Apr 20, 2012 | 06:47 AM
boosted_D's Avatar
This is not in the correct forum, should be in the drivetrain forum....but you could and should look into doing an H to B tranny set up, basically an adapter plate so you can run a B series tranny as they have better gearing options, and seem to be much stronger than H tranny's.
A healthy LS tranny with a LSD added would probably make you happy.
Old Apr 20, 2012 | 06:55 AM
h22apwrd95's Avatar
There is currently a group buy going on the Saenz gearsets. Here is the link. Only way you are going to hold power reliably for a longer period of time. Saenz group buy thread.
Old Apr 20, 2012 | 07:24 AM
Hidenplanvew's Avatar
actually a LS tranny would be worst then a H22 tranny.. you need to look into Geargear trannys.. You looking at 4k to 10k for one.. Pluse Bseries trans are going to start failing at that HP range too
Old Apr 20, 2012 | 07:51 AM
sshh's Avatar
So there is nothing to do but saving money....???
what about the competition twin plate clutch any reason not to buy it?
Old Apr 20, 2012 | 08:37 AM
Turbo-LS's Avatar
Comp twins are good but wait to see what trans your going to run first
Old Apr 20, 2012 | 09:21 AM
TheShodan's Avatar
Moderator
As he loses all acceleration using the LS transmission with that low *** 4.2FD.. He'll need the gearset in any transmission regardless of whether it is H or B for the kind of driving he's doing, but either way, an LS or LS-styled transmission is the last thing he needs..
Old Apr 21, 2012 | 11:12 AM
sshh's Avatar
what about act clutches? any of them will be good for me?
Thanks!
Old Apr 21, 2012 | 01:35 PM
sshh's Avatar
What about this trans is going to hold
http://shop.SYNCHROTECH-TRANSMISSION...-P9296-426.htm
And this act clutch kit
http://www2.advancedclutch.com/mobil...x?prod_id=8374
Old Apr 21, 2012 | 03:57 PM
Turbo-LS's Avatar
No that's just a rebuilt factory trans. Either turn the power down or start saving for a trans build.
Old Apr 26, 2012 | 12:52 AM
extralargenog's Avatar
Waiting to hear from you about the set.
racingcrx
Transmission & Drivetrain
Nov 3, 2009 07:23 PM
five point h0e
Oct 30, 2007 10:18 AM
driftt
Apr 6, 2005 11:06 PM
