h22 guys lets see your cam selections
Old 02-22-2006, 11:10 PM
b16hybridsol's Avatar
Default h22 guys lets see your cam selections
like it says, i'm having trouble deciding what cams to run with so i figured best thing would be to get all the setups together.
Old 02-23-2006, 12:07 AM
djnikko's Avatar
Default Re: h22 guys lets see your cam selections (b16hybridsol)
Good question, i'd like to know this too.
Old 02-23-2006, 12:10 AM
JDM4DRACCORD's Avatar
Stock ones work great correct?
Old 02-23-2006, 04:53 AM
The Weather Man's Avatar
Default Re: (JDM4DRACCORD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM4DRACCORD &raquo;</TD></TR><TR><TD CLASS="quote">Stock ones work great correct?</TD></TR></TABLE>
Thats what I've heard. I'm going to be using the stock cams also. Just getting adjustable cam gears though. Should all work out for the best.
Old 02-23-2006, 07:45 AM
accordm3's Avatar
Default Re: (TheKINGPin)
i am using skunk2 stage2... i put down 202 untuned... jun3's are the best tho... but the skunk pro series are supposed to be better
Old 02-23-2006, 08:11 AM
purpleh22's Avatar
Default Re: (accordm3)
I've contacted 3-4 of the better known shops in the country and got the same response. General thinking is that Aftermarket cam makers have not been able to produce cams that are better than the stock H22 cams. (turbo use) NA is a different story. The 'S' series H22 cams make a little more power and if a little low end torque is lost you probably won't miss it with an H22, especially in a light weight hatch.
Old 02-23-2006, 08:17 AM
93H22ACX's Avatar
Default Re:
im using stock cams...
Old 02-23-2006, 10:59 AM
booja's Avatar
jason (st00pid) told me to go with some NA cams like skunk2 stage2 cams with some springs and retainers
i think thats what he said to me
he likes NA cams in turbo cars... i think
i know he likes putting type r cams in b16's and such
Old 02-23-2006, 01:45 PM
410-Dragonz's Avatar
stock cams with cam gears is all you need on a turbo h22.
Old 02-23-2006, 02:06 PM
h22 civic's Avatar
Default Re: h22 guys lets see your cam selections (410-Dragonz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 410-Dragonz &raquo;</TD></TR><TR><TD CLASS="quote">stock cams with cam gears is all you need on a turbo h22. </TD></TR></TABLE>
yesir
Old 02-23-2006, 05:04 PM
Default Re: h22 guys lets see your cam selections (h22 civic)
not even type s'?
Old 02-23-2006, 11:02 PM
ozzyman's Avatar
If you ask Jason from Rage Performance (HT name Jason@Rage), he'll tell you that he uses stock H22 cams in his 725whp turbo H22 EG. Like some people said already... they havent been able to produce cams better than the stock ones.
Old 02-23-2006, 11:08 PM
Default Re: h22 guys lets see your cam selections (ozzyman)
thats what i've been seeing. I was just curious though, i've got an old mag i was looking at, that has HP Racings old blue h22 hatch and they were running type s cams in the 700whp range
BrowNKiD
02-23-2009 06:36 PM
bigblockhonda07
06-22-2007 04:31 PM
blusmke
02-05-2006 10:16 AM
Rad Racing
04-14-2005 07:31 PM
CBR
04-29-2004 03:07 PM
Quick Reply: h22 guys lets see your cam selections
