H.P. Limits of b18c1 w/... ?
Old May 14, 2005 | 05:21 PM
631 Teggy's Avatar
Default H.P. Limits of b18c1 w/... ?
What are the horspower limits of a b18c1 w/
*cometic .054in thick h/g (lowers compression to about 9.4:1 in stock b18c1)
*ARP head studs
*hondata s200b
*msd 6al
*endyn catch tank/breather
*70mm tb/skunk2 port matched im
*STOCK INTERNALS
*60k miles on motor
*peakboost kit
I know this seams like a ghetto way of making more power, but I'm a poor college student, and I'd rather spend money on a good tune and a good turbo kit then on forged internalls.
I searched to no avail (not for this setup). TYIA
PS: Would a blockguard be worth it with a setup like this? I wanted to keep it simple... Not looking for huge numbers, just something fast.
Old May 14, 2005 | 05:33 PM
Professor15's Avatar
So your going boost? lol i say you can past 300whp with a good tune and a good turbo kit on an internally stock gsr motor, thats more than enough for a poor college student...lol
Old May 14, 2005 | 05:58 PM
631 Teggy's Avatar
Default Re: (drchulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drchulo &raquo;</TD></TR><TR><TD CLASS="quote">So your going boost? lol i say you can past 300whp with a good tune and a good turbo kit on an internally stock gsr motor, thats more than enough for a poor college student...lol</TD></TR></TABLE>
Saving my pennies (not going to afford this till after summer). I dunno what i am going to do yet. I just wanted to know what power I could make with this setup.
Do I know you?
Old May 14, 2005 | 07:03 PM
salt's Avatar
Default Re: (631 Teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy &raquo;</TD></TR><TR><TD CLASS="quote">
*msd 6al
*70mm tb/skunk2 port matched im </TD></TR></TABLE>
Dont buy that stuff, for that price you can get a set of forged pistons, thats always been the weakest link in any of my stock honda parts. second weakest is rod bolts or rods.
Old May 14, 2005 | 07:19 PM
631 Teggy's Avatar
Default Re: (salt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salt &raquo;</TD></TR><TR><TD CLASS="quote">
Dont buy that stuff, for that price you can get a set of forged pistons, thats always been the weakest link in any of my stock honda parts. second weakest is rod bolts or rods.</TD></TR></TABLE>
Thanx for the suggestion bro - the IM/TB/ignition are already on the car. So only thing I have yet to buy would be the endyn breather. I wanted to stay away from any internals, because I won't have the money for labor...
Old May 14, 2005 | 09:02 PM
salt's Avatar
ok I see, good luck with you project, If I were doing it i would run low boost and install the headstuds and headgasket later with forged rods and pistons. I saw someone selling a set of used JE rods + eagles for less than $500(in the FI classified). I used a drill hone and installed mine myself and have perect compression and bearing clearance.
Before you buy the enydne breather, at least read the good 'crankcase evacuation' thread. your stock PCV system should be fine for now. spend the money on tuning and injectors
Old May 15, 2005 | 11:01 AM
631 Teggy's Avatar
Default Re: H.P. Limits of b18c1 w/... ? (631 Teggy)
So what horspower is safe on this setup? What size injectors for this setup? 310, 440, 550, 650? I was thinking 440cc would be sufficient for about 290 - 300whp... TYIA
Old May 15, 2005 | 11:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy &raquo;</TD></TR><TR><TD CLASS="quote">So what horspower is safe on this setup? What size injectors for this setup? 310, 440, 550, 650? I was thinking 440cc would be sufficient for about 290 - 300whp... TYIA</TD></TR></TABLE>Whose tuning your car? i suggest you go to NRG-tech...they can tune anything and build anything with top-notch quality.
Old May 15, 2005 | 11:23 AM
SOHC_MShue's Avatar
440's or 450's should be fine. If you want to build up the motor and push more power later on down the road then you may want to look into larger injectors than that.
Old May 15, 2005 | 12:20 PM
mtber's Avatar
Default Re: H.P. Limits of b18c1 w/... ? (SOHC_MShue)
Run atleast 550s so you have room to make more whp....
Old May 15, 2005 | 01:55 PM
hotrex's Avatar
Default Re: H.P. Limits of b18c1 w/... ? (mtber)
i made 319 whp ad its been holding up great for about 4 months now and i daily drive it and rape it hard....
i run 550s for injectors
Old May 15, 2005 | 04:16 PM
631 Teggy's Avatar
Default Re: H.P. Limits of b18c1 w/... ? (hotrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrex &raquo;</TD></TR><TR><TD CLASS="quote">i made 319 whp ad its been holding up great for about 4 months now and i daily drive it and rape it hard....
i run 550s for injectors</TD></TR></TABLE>
Nice, any info on your setup? Or is it 100% stock motor?
Old May 15, 2005 | 08:21 PM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
true- run atleast 550's cause 300 whp would bring 440 cc's up to atleast 80% duty cycle at 8000 rpm,would have no room for more hp. dont forget about a fuel pump. get a walbro 255 lph for the power you are looking for
Old May 15, 2005 | 08:23 PM
hotrex's Avatar
Default Re: (h22boy)
bone stock c1...... never even been opened.
Old May 15, 2005 | 08:25 PM
hotrex's Avatar
Default Re: (hotrex)
fuel pump is heresay.... i made high 200s hp wise on my built d series on a stock vx pump, and my gsr was hittin 10s a/f wise at 12 psi on the stock pump and 550cc injectors.
Old May 15, 2005 | 08:36 PM
631 Teggy's Avatar
Walbro 255lph is coming with the kit I am buying =D
So you guys think the head-studs and h/g aren't even worth it initially huh?
Old May 15, 2005 | 08:43 PM
hotrex's Avatar
nope
94integragsr
Jul 27, 2005 08:06 AM
WhoDoYouThink
Apr 12, 2005 04:10 AM
95EXcivicsleeper
Jul 24, 2004 06:31 PM
boostincrx
Dec 31, 2003 11:57 AM
JunIntegra
Dec 13, 2003 08:44 AM
