h-23 vtec frankensien
i was thkning about building a eg-hatch with a h23 lower and a h22 head. i was going to run 20 pounds of boost. i was also wondering what would be a good bottom end build,pistons,crank....anything will help thanks.
Re: h-23 vtec frankensien (EJtypeR)
I have H23VTEC in my prelude and its fun to drive. In my civic I have built GSR turbo. I would honestly stay away from H series. I spun bearing on my motor few times when it was put together right.
Re: h-23 vtec frankensien (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 »</TD></TR><TR><TD CLASS="quote">I have H23VTEC in my prelude and its fun to drive. In my civic I have built GSR turbo. I would honestly stay away from H series. I spun bearing on my motor few times when it was put together right.</TD></TR></TABLE>
your motor must have not been right if it spun a rod bearing.......H series make awesome power and down low to.
harv
harv
Re: h-23 vtec frankensien (1700anddroping)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping »</TD></TR><TR><TD CLASS="quote">
harv</TD></TR></TABLE>
noone likes to agree with me i swear, no one thought my coupe would run a 14 let alone a 13.7. now none thinks i will be able to make power with a h23 -22 combo with boost, everone doubts me...well they got another thing coming. im thinking with 24 inch slicks and my h puting out 5-600hp ill see thier jaws drop. so to all you doubters you obviously havent been working on engines long...
first all no one is hating or doubting you.if it spun a rod.the plain as day it was not put together right.thaqts good that you are doing h-series.i am an h man from way back....look in the drag racing section "1700anddropings street drag set up........then lets see your jaw drop.
harv
harv
H23 is ghey.Just bore your H22 1mm and you have a 2.3liter.Not worth the headache to go from a 2.2 to a 2.3 just from the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping »</TD></TR><TR><TD CLASS="quote">you think it's just that easy........you are looking at custom pistons.....unless you were going to use your stocks.... </TD></TR></TABLE>
i was going to have low compression pisons and some strong rods and bearings. not really sure of what to go with yet.
pm me man i will help you w/this......go look at my set up in the drag racing section.then get back to me..don't worry about what other people will say.it only matters what you like and are wanting to build.
harv
harv
H motor makes good power and torque, but you don't want to use the H23 bottom end. Rod to stroke isn't all that great and the same power can be had with the H22 bottom end. Best route is to deckplate H22 with custom rods, but that depends on your financials.
Re: h-23 vtec frankensien (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">H motor makes good power and torque, but you don't want to use the H23 bottom end. Rod to stroke isn't all that great and the same power can be had with the H22 bottom end. Best route is to deckplate H22 with custom rods, but that depends on your financials.</TD></TR></TABLE>
Yep. There are a few guys that run high horsepower h23 vtec's but a lot of guys that do it end up spinning bearings. It can be done but you need to do your research so you do it right the first time. Search in the prelude forum under archives... you'll find all the info you'll ever need.
