gt4067 question. oil comming out of compressor housing
ok on the dyno when tuning everything is fine no oil anywhere. when i take it to the track oil comes out the compressor housing. it blows out. it only does it when there is a load. it is not not the seals not burning any oil at all. no oil in the charge pipe at all. it holds a steady 28lbs. im lost on how its blowing oil out the compressor housing. i do have to much crank case pressure right now that i have to take care of.
Re: gt4067 question. oil comming out of compressor housing (Adi Radoncic)
Do you have an oil restrictor fitting in your fed line ?!
Also like Adi Radoncic said , make shure that the oil return line has no bends because it restricts oil from getting out from the turbo and from somewhere it has to escape !!
Do you run a filter on your turbo ? because it might be dirt on the inlet housing !
big-cat
06-15-2007 03:53 AM
Cyber ITR
02-10-2007 08:44 AM
Tuesday Club
08-17-2006 08:09 AM
