GT35R.. specs/help??
Old Sep 2, 2004 | 02:36 AM
  #26
MrBond's Avatar
Default Re: GT35R.. specs/help?? (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">The turbine wheel is actually pretty small. It is 68mm (2.67") exducer.
I am not sure what Shodan is talking about w/ the .63 having a 2.5" outlet.... The exducer on the wheel is 2.67", and that means that the outlet on the housing is going to be AT LEAST that. If you run a 2.5" downpipe on this turbine wheel it is going to cover up the outlet and choke off flow.
As for the .82 having a 3" outlet.. Both housings are still the same size at the exducer wheel. The only thing that is going to changing on the outlet between the .63 and .82 is the .82 might be bored at an angle compared to the .63 being bored strait out at about 2.7".. Either way if you have a 3" downpipe on it, then you are not going to be chocking flow on either housing.
Do the .63.</TD></TR></TABLE>
68mm exducer on the turbine you say ?
I think that would be the turbine inducer...
Exducer is 64mm on my GT3561S, and I had a outletflange for it lasercut to fit the 65mm outlet of the 5-bolt t3 style housing perfectly...
We welded a cone right onto this flange going over to 3" ID...
The turbine wheel exducer is the same size on both the .82 and .63AR, its just that the .82 come with a coned outlet, so you dont have to make this on the downpipe.
If I'm not mistaken, the .63 can be bought with a 4bolt 3" oulet also?
MrBond.
Old Sep 2, 2004 | 03:10 AM
  #27
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (ZoRG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZoRG &raquo;</TD></TR><TR><TD CLASS="quote">Thanks to Direp972 or else this might have gotten out of control, people might end up selling you a lag kit .</TD></TR></TABLE>
Ask him where he learned his stuff. No need for me to post in FI anymore when we have chris. LOL. He is my crew chief for a reason!
Old Sep 2, 2004 | 03:48 AM
  #28
ZoRG's Avatar
Default Re: (Arturbo)
coo coo
Old Sep 2, 2004 | 07:14 AM
  #29
DIRep972's Avatar
Smarter than you
Default Re: GT35R.. specs/help?? (MrBond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrBond &raquo;</TD></TR><TR><TD CLASS="quote">
Hey Mr. Bond. hummmm, I havn't had a GT35R in my posession for awhile. but right here- http://www.limitengineering.com/gt-35-full.jpg on the garrett compressor map it lists the exducer as 68mm. Do you think its possible that you have a GT3261S? who did you get the turbo from? If you look here- http://www.limitengineering.com/gt-32-full.jpg the GT32 has a 64mm exducer on the turbine.
Old Sep 3, 2004 | 03:25 PM
  #30
MrBond's Avatar
I believe you are wrong there DIRep972...
Mine is indeed a GT3561S,
and you wrote a post here also:
https://honda-tech.com/zero...age=3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">GT3561E specs are as follows-
Compresssor:
-GT40 56 trim compressor wheel. 61mm inducer/82mm exducer. 6 blade wheel
-.60 AR T04e Precision Compressor housing
-----non ball-bearing. 360 degree thrust bearing.
Exhaust:
-GT35 84 trim exhaust wheel. 77mm inducer/64mm exducer. 10 blade wheel
-T3 .63 AR 5-bolt Precision Exhaust Housing
*T04S .70AR Precision Compressor housing is available as upgrade.
*Ball-Bearing is available as upgrade.
-T3 .82, T4 .68, and 4-bolt exhaust housings are available as option.
This turbo spools the same as an SC61 but makes 15-20 more HP.
I do not know the prices on all this stuff. PM Arturbo if you have any questions.</TD></TR></TABLE>
Old Sep 3, 2004 | 03:57 PM
  #31
DIRep972's Avatar
Smarter than you
hummm. haha. that is wierd. I cant remember where I got the information that I posted in that thread. Garrett did recently update their catalog and those are the specs I have been using since, but im wondering if the new update has errors? good catch! nothing gets past Mr. Bond
Old May 8, 2005 | 07:36 AM
  #32
Muckman's Avatar
Moderator in Chief
Default Re: GT35R.. specs/help?? (ManikGSR)
This is a great thread but one question didnt get answered that Id like to know also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ManikGSR &raquo;</TD></TR><TR><TD CLASS="quote">4. how much HP advantage does the .82 A/R have ove rthe .63 A/R??</TD></TR></TABLE>
Old May 8, 2005 | 08:35 AM
  #33
Turbo-charged's Avatar
Default Re: GT35R.. specs/help?? (Muckman)
i run a .63 GT35R on my 85mm LS/VTEC. stock B16 head with springs and retainers, no porting. i made 570whp on 18psi, and 616whp on 24 psi. i guess the turbo was running out of breath even though its rated to a higher boost level, because adding timing was making more horsepower than increasing the boost....but upping the boost was obviously making torque increase due to the harder/quicker spool up. i see full boost between 4500 and 5000 rpm using an tubular manifold i made myself. 2.5 inch charge piping hot side, 3 inch cold side with precision 750hp intercooler. horsepower climbs to about 9000 rpm and holds between 9000 and 9500 rpm where i let off. im pretty much a firm beleiver on a street car to go with a smaller AR.
  #34
_entropy's Avatar
505 WHP @ 15 psi, .63 GT35R, 84mm LS/VTEC, Race Gas
604 WHP @ 27 psi, .63 GT35R, 84mm B16A
485 WHP @ 17 psi, .63 GT35R, 81.5mm GSR, 92 Octane!
Those power numbers are more than enough for me to decide that a .63 A/R hot side is big enough.
Old May 8, 2005 | 11:22 AM
  #35
manekDC2.'s Avatar
Default Re: GT35R.. specs/help?? (Napoleon Dynamite)
well i scrapped the GT35R, and decided to go with th GT40R a while back.. with the .85 hott side housing and a pro-am full-race top mount.. getting my block back from ERL in a few weeks, and still fabbing up the car.. if you care here are my specs on my block..
ERL Darton Sleeves
BME (Bill Miller Engineering) 9:1 84mm pistons and upgraded wrist pins/rings
Carrillo H-Beam rods with CARR 70ft/lb bolts
ERL 5-main block girdle
ACL race bearings
ARP stud kit
looking to make 500whp on pump gas.. but a ton of work has to be done yett, ill keep you posted..
Old May 8, 2005 | 02:51 PM
  #36
siblues's Avatar
I would love to see that girdle installed and good luck with the build
Old May 8, 2005 | 05:17 PM
  #37
manekDC2.'s Avatar
Default Re: GT35R.. specs/help?? (siblues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">I would love to see that girdle installed and good luck with the build </TD></TR></TABLE>
thanks
Old Jun 7, 2005 | 06:20 AM
  #38
downeyballz's Avatar
i have a .82 gt35r on my b16 with an al tranny. im not getting full boost till like 6000rpm and its even worst because i have an ls tranny so im out of boost everytime i shift. i think there must be a problem somwhere making it spool so late. but i think im going to switch the exhaust housing to .63 and make a new 2" charge pipe from the turbo to intercooler. anyone know a good place to buy a new exhasust housing?
Old Jun 9, 2005 | 12:58 AM
  #39
Default Re: GT35R.. specs/help?? (downeyballz)
any help?
Old Jun 9, 2005 | 01:17 AM
  #40
wolve's Avatar
switch tranny!
Old Jun 9, 2005 | 06:32 AM
  #41
Default Re: GT35R.. specs/help?? (wolve)
i had the tranny already and i like it becasue of the long 5th gear (i do alot of highway driving) but its on its way out. i dont see how the tranny could effect the spool of my turbo though
Old Jun 12, 2005 | 07:29 PM
  #42
93LSivic's Avatar
We should have Dru's block back shortly. I dont think I want to give it back.......anyone ever hear of a $4,000+ street shortblock, well now you have sucka
bostdteg
Dec 8, 2006 01:41 PM
Big Josh
Oct 28, 2003 03:06 AM
boostedsi1
Jun 15, 2003 07:43 AM
fastludeh22
Oct 29, 2002 12:18 PM
snt78
Jul 23, 2002 03:17 PM
