Gt35R or Gt40r
Gt35R or Gt40r
I might be able to get my hands on a Gt40R next week.......not sure if there would be a big Difference between the 2 turbo's for street use on a Fully built H22a. Please Help me.
Re: Gt35R or Gt40r (icebergli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icebergli »</TD></TR><TR><TD CLASS="quote">I might be able to get my hands on a Gt40R next week.......not sure if there would be a big Difference between the 2 turbo's for street use on a Fully built H22a. Please Help me. </TD></TR></TABLE>
bump
bump
Some specifications for you.
* GT35R Compressor
Inducer - 61.3mm
Exducer - 82mm
Trim - 56
* GT35R Turbine
Exducer - 62.3mm
Inducer - 68mm
Trim - 84
* GT40 Compressor
Inducer - 57.9mm/64.6mm
Exducer - 82mm/88mm
Trim - 50/54
* GT40 Turbine
Exducer - 65.7mm/70.5mm
Inducer - 77mm
Trim - 73/84
* GT35R Compressor
Inducer - 61.3mm
Exducer - 82mm
Trim - 56
* GT35R Turbine
Exducer - 62.3mm
Inducer - 68mm
Trim - 84
* GT40 Compressor
Exducer - 82mm/88mm
Trim - 50/54
* GT40 Turbine
Inducer - 77mm
Trim - 73/84
Re: Gt35R or Gt40r (b16sedan)
street car go gt35r
race only go 40r
unless you drive on race gas and slicks all the time that power is useless on the street. unless you want to be a dyno queen
race only go 40r
Re: Gt35R or Gt40r (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">street car go gt35r
race only go 40r
unless you drive on race gas and slicks all the time that power is useless on the street. unless you want to be a dyno queen</TD></TR></TABLE>
I would just roll around on Slicks then all the time!
race only go 40r
Re: (RTErnie Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie Motorsports »</TD></TR><TR><TD CLASS="quote">yeah...those are called RWD cars. </TD></TR></TABLE>
hahahaha lmfao
If I where you I would go with the GT35R but thats just me
hahahaha lmfao
race only go 40r
Geoff@Full-Race said the powerband of the ball bearing 40R felt smoother than most small T3/TO4E's to him, and was very useable on the street.
race only go 40r
there may be a problem with the gt40r being too big. when you size the turbo to big for the motor the turbo operates out of its efficency range and outside of its surge line in the compressor map. it can lead to bearing failure or wheel damage ..its about 750$ to rebuild a ball bearing turbo. This may or may not apply to the 40 R
