GT30r issue
Old May 29, 2011 | 10:28 PM
ryguy2588's Avatar
Default GT30r issue
I have a GT3082r. I put some oil in the center cartridge and put it in the position where it would run and just spun the wheel by hand. I found that there was some oil on the compressor wheel and there were a few drops dropping out where the intercooler pipe connects to the compressor housing. There was no pressure, it was just some oil sitting in the cartridge. I assume bad oil seal, but I know a cartridge can't be rebuilt, but can a seal be replaced? There's not any shaft play. Or am I just out of luck?
Old May 30, 2011 | 06:29 AM
ryguy2588's Avatar
Default Re: GT30r issue
Anyone?
Old May 30, 2011 | 06:32 AM
TheShodan's Avatar
Moderator
If you're saying that you're finding slight amount of oil in the compressor housing and the car wasn't run, did you stand the turbo on its compressor side vertically? If so, nothing to worry about, as the sealing ring allows a little bit to go through. its when its under pressure, that's when the sealing ring expands and seals up.
If what your describing is oil in the compressor housing as the car has been running, that means you have a crankcase issue, and need a proper catch can.
But no, you can't replace a sealing ring on a GT-R series turbocharger.
Old May 30, 2011 | 05:22 PM
ryguy2588's Avatar
Well its a used turbo and I haven't put it on yet. I was making sure that there wasn't any oil leaking before I put it on.
I put oil in the turbo, turned it like it was in use, and spun the shaft for about 5 minutes.
Old May 30, 2011 | 05:23 PM
ryguy2588's Avatar
I looked in the compressor housing and saw a little oil coming out.
Old May 30, 2011 | 05:25 PM
ryguy2588's Avatar
And then I took off the housing and saw the base of the wheel was damp and there was some oil in the housing.
Old May 30, 2011 | 05:27 PM
ryguy2588's Avatar
The pics might be overkill, but I just want to make sure that either the seals are bad or it's just me being too worried about it before I use it or get rid of it. Thanks.
Old May 30, 2011 | 05:28 PM
ryguy2588's Avatar
It wasn't standing up at all. I just kept it in the position in the first couple pics.
Old May 30, 2011 | 07:45 PM
TheShodan's Avatar
Moderator
Doesn't seem like the worse thing in the world. It has to oil pressure PASSED the ring seal in order for it to be damaged. Keep it horizontal, try it on, make sure you're using the correct .030" restrictor on the oil feed, and give it a shot.
Old May 31, 2011 | 08:08 AM
ryguy2588's Avatar
Ok. Thank you so much!
Old May 31, 2011 | 08:29 AM
TheShodan's Avatar
Moderator
One other question. When you took the compressor cover off. was the turbo sitting horizontally when you removed that cover?
Old May 31, 2011 | 08:40 AM
ryguy2588's Avatar
Yes I made sure to take it off while it was horizontal.
And this is the restrictor I have. It's tiny. Is it the right one? Should I just order another one?
Old May 31, 2011 | 08:41 AM
ryguy2588's Avatar
I had to roll it from one side to the other to get to all of the bolts, but it stayed horizontal.
Old May 31, 2011 | 09:07 AM
TheShodan's Avatar
Moderator
The restrictor you picked up, should be .030" opening. you can't tell much by the eyeball, but it looks to be right.
Old May 31, 2011 | 09:15 AM
ryguy2588's Avatar
Ok. Thanks so much.
Old Jun 9, 2011 | 02:17 PM
sh!ft's Avatar
Who the fack changed my title?!
so let me get this straight, you are saying this turbo is acceptable to run like this? have you personally ever ran a turbo like this on a motor or in your car before? are 100% certain this will not effect the motor/turbo in any way, shape, or form??
Old Jun 9, 2011 | 02:27 PM
TheShodan's Avatar
Moderator
(This is also in the PM I responded to)
I personally wouldn't have bought the turbo in the first place due to the mismatch of the wheel configuration that the GT3082R gave. Considering I don't know its full previous treatment, its not in my hands, I don't know if it was upside down for any length of time, There are a lot of variables to consider when seeing if thing really works, that can't be answered by pictures, no matter how good they are. I'll be honest, I'd have my doubts about this particular unit, (obviously so do you since you keep bringing this up,) but I have run some turbos like this before. It's not preferrable, but when it was needed I did, and it turned out ok. I don't know about this particular unit.
Sounds like you have some doubts, and for the price being asked, I don't blame you. Listen to your gut... Your spidey sense is tingling for a reason. If there is doubt, then don't buy it, and look for alternatives.
Tuesday Club
Aug 17, 2006 08:09 AM
watsvtecEK
May 19, 2006 01:21 PM
boostdummy
Nov 29, 2005 07:17 AM
.RTErnie
Jul 9, 2005 05:58 PM
