GSR Turbo Setup Suggestions and Expectations
Old Nov 9, 2011 | 07:03 AM
JPerkMr954's Avatar
Default GSR Turbo Setup Suggestions and Expectations
Im now about to try and get into the boosted life but this is new to me so I came here for information and advisement....
Looking to boost a GSR.. nothing has been bought yet towards the setup.. Need a little more information..
Im looking to keep the car a daily driver.. just have some fun with it...I want to keep ps and a/c... I dont want to do any block work (at least not now) Looking to get about 250-260whp.. Im considering the t3/t4 setup but im not sure if that will be too small..
Any input and suggestions for me as a starter will help...
Old Nov 9, 2011 | 07:11 AM
kbouchard1092's Avatar
Default Re: GSR Turbo Setup Suggestions and Expectations
t3/t4oe 50 trim.... or you could go Ball bearing and get the GT28 , You didnt mention youre budget tho. There a big difference in price between them
this seems good for youre goal
The NEW GO-AUTOWORKS Street Turbo System is our entry level system offered for those that are looking for a great kit, that has good power potential at an affordable price. Great for stock block setups! The system is capable or 200-300hp. this kit uses T3 60 .48a/r
http://www.go-autoworks-store.com/gostkit.html
Old Nov 9, 2011 | 07:14 AM
TheShodan's Avatar
Moderator
The best way is to start on the FAQs in the forum section (highlighted in grey) to get started. Learn as much as you can, and build a perspective list of things you need. Knowing the current health status of your engine is paramount if you don't plan to build on it. This imeans leakdown/compression testing, mechanical readiness, etc.
Then, start looking at setups from the GS-R that are similar to your goals and used. Never use PSI as a determining factor of what you want. Use a power level that you feel comfortable with. You can always turn up the boost later if needed. The search engine here is not that good, but key work GS-R turbo Honda-tech via Google, and you'll find better answers. There's even an entire thread of GS-R Stock block builds that are available in this forum. Use Google to find that thread.
Have a budget in mind. This is isn't slapping together another bolt on, even if a kit says it is. Once you have that budget add 50% to that budget for the little things.
Lastly, No Godspeed parts or any useless nonsense from E-bay. If the deal looks too good to be true, it definitely is.
As kbouchard1092 stated, the Go-Autowerks setups are a great way to start. The turbo choices are many (a 50 "trim" is just a suggestion of about 3-5 units that can work with the stock block. That's why I suggested using the GSR Stock block thread to determine an area of turbocharger to use.)
Once you have answered those questions, get back with us. Use this thread as a segway.
flangemastermike
Jun 17, 2014 12:12 PM
401tuner
Feb 21, 2007 03:54 PM
a1320addict
Nov 8, 2006 07:38 PM
GsRHatchy1320
Aug 28, 2004 09:55 AM
pip9
Dec 18, 2003 03:59 PM
