anyone using diamond pistons?
Old Nov 8, 2011 | 07:22 PM
MR.johnson's Avatar
Default anyone using diamond pistons?
looking at my options for pistons next year. anyone having god luck with diamonds?
Old Nov 8, 2011 | 08:23 PM
TheShodan's Avatar
Moderator
Default Re: anyone using diamond pistons?
Diamonds are a STAPLE of Chicago and Detroit. That company is fantastic when it comes to options and compressions. You can even purchase a 5th piston at a nominal charge so that in case something goes wrong, you have another one right there ready to go.
I plan to order a set myself this year. Better than JE and my beloved Wiseco Even..
http://www.diamondracing.net/
Old Nov 9, 2011 | 03:16 AM
MR.johnson's Avatar
what "options" should i get coatings ect. any dome, skirt i should ask for?
Old Nov 9, 2011 | 06:52 AM
LocoJoe's Avatar
Im interested for more info.
Old Nov 9, 2011 | 07:06 AM
TheShodan's Avatar
Moderator
There are literally so many options that the possibilities are limitless, I would give them a call.
I used a 10.2:1 compression 84mm to match with a GE sleeved B18c Block with a coating on the skirts ( I know the coaters they use, so they are a trustworthy source).
They are a local hero in the Motor City. What I like most is the fact that they are ISO9001 cert (http://www.diamondracing.net/162Diam...EXP-1-2009.pdf)
Give them a CALL, and discuss your options. They like that better than E-mail
http://www.diamondracing.net/ - numer is on the bottom.
Old Nov 9, 2011 | 07:40 AM
Spawne32's Avatar
how much did they cost you shodan?
Old Nov 9, 2011 | 07:43 AM
TheShodan's Avatar
Moderator
Can't released what I paid, but the average is about $480-$500. The fact is though that this is cost for custom compression, skirts, profiles, etc. I think that is the real benefit. PLUS, you can even purchase single units if needed.
Old Nov 9, 2011 | 08:09 AM
Spawne32's Avatar
Im assuming you have dealer pricing, so 20% less then what you said, which actually isnt bad at all considering regular old box pistons cost about the same.
Old Nov 9, 2011 | 08:18 AM
TheShodan's Avatar
Moderator
Not all dealer pricing is the same. Never assume any percentage.
Menace4U
Jul 20, 2015 02:10 PM
kgreenhaw
Aug 3, 2012 12:24 AM
Circusraven
Jun 22, 2008 01:40 PM
hovic
Feb 25, 2007 06:47 AM
crx1856
Nov 3, 2003 12:00 AM
