GSR Turbo Question?
Old Aug 4, 2007 | 01:56 PM
del_orson's Avatar
Default GSR Turbo Question?
Ok, Im rebuilding my worn out GSR. Im doiing rods and pistons, but I sort of want to not spend the money sleeving it. Just wanted to know how much boost I could run on stock sleeves with low compression pistons, and would a block gaurd help or do they just suck anyways. I I get good enough answers that lead to resleeving, then I will put sleeves in. Thanks for the help.
Old Aug 4, 2007 | 02:17 PM
EK-ek's Avatar
Default Re: GSR Turbo Question? (del_orson)
i would say about 8-9 psi. on a stock gsr would be fine.
Old Aug 4, 2007 | 03:19 PM
lsvtechatch92's Avatar
Default Re: GSR Turbo Question? (EK-ek)
dont listen to this guy^^^^ stock sleeves are fine just depends on your goals... tuning is the key
Old Aug 4, 2007 | 03:27 PM
KeyserSoze's Avatar
If you are asking about a max psi #, then you need to do a bit of research. 10psi on a t25 is going to make much different power than 10psi on a gt35. Power is the most common variable used to predict failure with known engine components.
Most say:
Stock block - 300whp
Forged slugs and rods - 400whp
Sleeves and forged internals - A lot.....
Here's a thread on power made with stock sleeves.....
https://honda-tech.com/zerothread?id=892257
GL.
ldyer1994
Feb 12, 2015 02:29 PM
rudedawg
Aug 13, 2012 06:53 PM
Jake92eg
Mar 31, 2006 10:56 AM
mugencivic94
Dec 29, 2005 08:12 AM
MikeySpec
Nov 23, 2001 07:50 PM
