gsr turbo NEED HELP!!!
Im having problems with my car? when i run my car with 550cc injectors it would bog at 4000 rpm while in neutral reving and when driving it sputters like cazy with my p28 chip, which the chip on it was tune for the 550cc but couldnt get tune because of this situation.when i used my stock injectors with a ebay chip it dont bog or sputter at all? Please help!
MY SETUP:
48ar t3/t4 turbonectic
presicion intercooler
550cc injectors
fuel rail
fuel pressure regulator
255Lp fuel pump
jg intake manifold
greddy boost controller
MY SETUP:
550cc injectors
fuel rail
255Lp fuel pump
jg intake manifold
Re: gsr turbo NEED HELP!!!
MY SETUP:
550cc injectors
fuel rail
255Lp fuel pump
jg intake manifold
MY SETUP:
550cc injectors
fuel rail
255Lp fuel pump
jg intake manifold
I dont understand what your saying....the chip that you put on your ecu is chip to run the 550cc. and it sputter...but was tune on the 550cc...did you use the same map sensor that was use to tune the 550cc...you might be running your stock map. but the map that use to tune those 550 is a different map....like a 2.5bar or 3bar or somthing deferent than stock....or the other way around...you know what i mean....
Yes I used the same map sensor but still did the same. The guy that tune my car he couldn't get it tune because it was sputtering so he made me a chip to be safe to drive home.
[QUOTE=KingkongDC2;39038277]i did take it to get it tune but the tuner didnt know whats wrong![
so your tuner was tuning it and just give up on it....
or did he just took a look at it and tell you to go home....did he give u a dumb look...
How much boost are you running? Do you need resistors for your injectors? If you chipped your car with one of ebay than that your problem should be able to fix with a real tune.
JDM turbo DC
03-24-2006 05:44 PM
trooper0641
07-04-2004 07:39 AM
