GSC Turbo Cams Vs 01 ITR Cams... Better spool and 30whp+ Gain...
#1476
Re: GSC Turbo Cams Vs 01 ITR Cams... Better spool and 30whp+ Gain...
If your block/head has been decked/milled just putting them at 0,0 won't work. You'll need to degree them. I couldn't get them to idle in my car when set at 0,0 so I took them out. Then I realized I wasn't accounting for the change in height due to block/head work. Next time the motor is out the GSC cams are going back in and I'll be sure to degree them.
#1478
I'm considering the Tuner 1 cams now as a middle ground between CTR/GSC T1 cams. I think that should be the best "sweet spot" cam profile for power past 9K and the small exhaust profile. Shouldn't sacrifice anything down low. Easy on valvetrain too I guess.
#1479
Moderator
Better yet.
#1480
Thank you very much for the video. Definitely sold on the Tuner 1's currently.
#1481
I put together a video 5 years ago (Search GSC vs. Tuner 1 on Youtube) in which I stated exactly that back then. Valvetrain requirements are apples-to-grapes different, so you can't say one is easier on the valvetrain than the other.
Better yet.
https://www.youtube.com/watch?v=bNMGqZ6YvcU
Better yet.
#1482
I just got my car up and running with the GSC T1's... After a week of running great I ran into some electrical issues...
Map sensor was an omni 3 bar -- Was pulling -8 to -7 inhg at idle.. I know others were around the -6 to -10.. So thought that was all good and normal - Car had hiccup cruising in the 2-2.5k rpm range instead of 3-3.5k range as I've seen others have... but didn't seem abnormal.
Now I find out I got the car street tuned with a broken map sensor.. Get a new sensor on there and I'm pulling -12inhg at idle -which seems high...
Wondering for others with LS/Vtec - On the GSC t1's do you just 0/0 or as I've read 100 different opinions on the matter.. advance intake +2 and retard exhaust -2... some just set up 0/0 and ensure belts tensioned correctly - and lastly others like me advance both intake / exhaust a tad...
I'm wondering now if I didn't set them right... I did all my P2P and V2v combinations so I know I've got MILES of clearance with my current pistons and stock valves..
Just trying to get a good idea if where I've set them seem accurate to others before I spend the next week fine tuning the part throttle areas.
Thanks
-Josh
Thanks
-Josh
#1485
Moderator
Comments are within your statements in blue
-12in/Hg is still within the normal range. It just means that after your street tune, one of your vacuum lines may have cleared up. So that's fine -12in/Hg is still within normal parameters
What you do is set it up so that it is full theoretical 0,0. Meaning that you've compensated the intake and exhaust timing so that it becomes 0,0. In essence. Make sure that the belts are tensioned correctly and if you have to advance both intake/exhaust a tad, its ok. But the timing needs to equal itself out to full zero.
Sounds like you're in the right direction.
Thanks
-Josh
Thanks
-Josh
#1486
Hey ... thanks for the quick response.. The omni map sensor was cracked straight down the middle so the -8 to -7 was an inaccurate reading. I was basically just paranoid once I got a new sensor on that the idle pressure was pulling so much higher.. I'm still stuck on the theoretical part but I've made a couple assumptions - Head / Block milled .005 so thats 1* total and ls block / vtec head - 1* - how I came up with 2 for starters.
I really just wanted to make sure I was on the right track or if I should reset to true 0/0 and wait until dyno to move them up together in 1* increments until its right.
Thanks for the reassurance.
So far I love these cam's .. The little bit I've driven even out of boost feels 10x stronger than old LS head / cams.
#1487
Moderator
Go back to "0/0".. Don't try to recorrect them on the dyno. Unlike other companies, those camshafts were made to work best at 0,0, and not changing any increments like the Skunk2 Pro Series.
In fact, many users that are not on H-T much that use these cams use stock cam gears. (That's right, I said it..... STOCK). That's how you know you need to be at true 0,0..
#1488
It's wU to the sOLdiEr!
after watching myles latest run and congrats on breaking another world record. im curious if his car downforce would improve more if he had a jdm front end since it was designed for that.
(yes i know this is a mugen front bumper but im still curious)
#1489
To be honest im not sure why that hasnt been changed yet...The duck tape thing was a good "quick" fix. But now that the car is dedicated to this purpose =/
#1490
Great cams for sure...They keep making power up top..!!
Dynod my car up to 9k and decided to take it up to 9.5k and a 30whp difference..!!
#1492
#1494
Funny you guys say that, I received an email a few days ago from GSC that the T1 cams were back in stock.
#1495
Moderator
Check out Cole D and some of the others on the Forced Induction classifieds who were dying to sell theirs., or call GSC directly. Stop looking at sites.. Lot of companies don't update them like Amazon.
I can get some in about 3 days, no kidding.
#1499
I only buy parts brand new from manufactors. Or from about four trusted vendors. I find it hard to maintain interest, when someone cant answer or reply to a few emails within the period of a year concerning purchasing. Whether it be responding a few days later or a couple weeks later. Guess i didnt want them bad enough to call.
#1500
Moderator
