Greddy Type S BOV
Old Jun 27, 2008 | 03:09 PM
b16a95eg's Avatar
Default Greddy Type S BOV
Does anyone have any pictures or info on where the vacuum lines go on this? i'm just kinda wondering. i've searched a little but couldnt really find anything. theres 2 nipples for them to connect to.
Old Jun 27, 2008 | 04:00 PM
KevronsEG's Avatar
Default Re: Greddy Type S BOV (b16a95eg)
Use the top one for Vac. and the bottom for Boost(only if you want to its not needed)
Old Jun 27, 2008 | 04:04 PM
b16a95eg's Avatar
so would i just plug the bottom one off?
Old Jun 27, 2008 | 05:58 PM
DOHC_16v's Avatar
Default Re: (b16a95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a95eg &raquo;</TD></TR><TR><TD CLASS="quote">so would i just plug the bottom one off?
You can leave it open.
Connecting it will help with compressor surge at low boost, it's meant to be connected to the compressor outlet. I have it unplugged for now, and I get a bit of compressor surge no matter how much I loosen the spring tension.
Old Jun 27, 2008 | 06:03 PM
b16a95eg's Avatar
ok sweet thanks for the help.
Old Jun 27, 2008 | 07:09 PM
Tjabo's Avatar
Default Re: Greddy Type S BOV (KevronsEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevronsEG &raquo;</TD></TR><TR><TD CLASS="quote">Use the top one for Vac. and the bottom for Boost(only if you want to its not needed)</TD></TR></TABLE>
Wow, I'm confusd. . . Does this make sense? It seems like you're saying to hook the boost tube to the bottom side of the diaphragm, which will essentially fight against the spring pressure when you're under boost, and want the BOV to stay closed. . . Did I misunderstand?
Old Jun 28, 2008 | 03:29 AM
DOHC_16v's Avatar
Default Re: Greddy Type S BOV (Tjabo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tjabo &raquo;</TD></TR><TR><TD CLASS="quote">
Wow, I'm confusd. . . Does this make sense? It seems like you're saying to hook the boost tube to the bottom side of the diaphragm, which will essentially fight against the spring pressure when you're under boost, and want the BOV to stay closed. . . Did I misunderstand?</TD></TR></TABLE>
The pressure will be the same or equal at the top. It will make the BOV more sensitive when there is a little bit of boost at the compressor outlet but very little or none in the intake manifold...
blinx9900
Jan 6, 2008 11:20 AM
Hyaboosta
Jun 21, 2006 12:32 PM
yusoslo
Apr 22, 2004 12:59 PM
torr
Dec 4, 2003 01:23 PM
NOSED_CRX_VTEC
Oct 29, 2003 02:28 PM
