Greddy Trubo Install Prob??? Oil Pressure straight Union 1/8 Snaped??
Ok I was installing my Greddy kit and I over tightened the Oil pressure straight Union and it snapped. This kit is for a SOHC. I would like to know of were I can get a replacement for it? Any help of were to get one is great.
Re: Greddy Trubo Install Prob??? Oil Pressure straight Union 1/8 Snaped?? (EK-TSOHCV-TechRider)
Home Depot only sells NPT fittings. Is that a 1/8 BSPT to 1/8 NPT adapter? McMaster-Carr has just about everything. Shipping is very fast.
I tried my local hardware and automotive store and I swear I went through at least 8 qtrs of mobil 1 trying to find a fitting that fit and didnt leak. I ended up buying a new oil feed kit. I tried to order that from Greddy and was told it could take months to get
Re: Greddy Trubo Install Prob??? Oil Pressure straight Union 1/8 Snaped?? (B16A Grenade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A Grenade »</TD></TR><TR><TD CLASS="quote">Home Depot only sells NPT fittings. Is that a 1/8 BSPT to 1/8 NPT adapter? McMaster-Carr has just about everything. Shipping is very fast.</TD></TR></TABLE>
Were would I look for this adapter on the Mcmaster-carr.com site. And I believe its 1/8 npt on both sides.
If you're sure it's NPT on both sides, and you want brass (stainless is also available), it's on page 19. I can't find a way to link directly to the part, but just scroll down and you'll see it. If you want brass BSPT x NPT, it's on page 21.
edit...to go directly to a page, just type in "page 19" or "page 21" under "find."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A Grenade »</TD></TR><TR><TD CLASS="quote">If you're sure it's NPT on both sides, and you want brass (stainless is also available), it's on page 19. I can't find a way to link directly to the part, but just scroll down and you'll see it. If you want brass BSPT x NPT, it's on page 21.
edit...to go directly to a page, just type in "page 19" or "page 21" under "find."</TD></TR></TABLE>
Im not sure on if it is a npt or bspt in the manual it is says they are npt but I think Ill order both.
I'll look at my old Greddy oil feed parts later and see what you need. Or, you can order both parts, because it's less than $6 total.
So I need NPT on both sides the bspt side didnt fit. I ordered both the part #4860K611
and the #5485K21
Modified by EK-TSOHCV-TechRider at 8:16 PM 6/1/2005
Modified by EK-TSOHCV-TechRider at 8:17 PM 6/1/2005
and the #5485K21
I haven't found the box that contains my Greddy oil feed parts, but in my Greddy parts list, part 20 is 1/8 PT-1/8 PT, and part 21 is 1/8 PT-1/8 PF. I read that Japanese 1/8 PT is the same as 1/8 BSPT. Later on in the installation manual, it lists the T specifically as being 3 way 1/8 NPT. The PT-PT fitting goes between the block and the T. The PT-PF goes between the T and the oil feed. Which one did you break?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A Grenade »</TD></TR><TR><TD CLASS="quote">I haven't found the box that contains my Greddy oil feed parts, but in my Greddy parts list, part 20 is 1/8 PT-1/8 PT, and part 21 is 1/8 PT-1/8 PF. I read that Japanese 1/8 PT is the same as 1/8 BSPT. Later on in the installation manual, it lists the T specifically as being 3 way 1/8 NPT. The PT-PT fitting goes between the block and the T. The PT-PF goes between the T and the oil feed. Which one did you break?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-TSOHCV-TechRider »</TD></TR><TR><TD CLASS="quote">
The PT-PT fitting goes between the block and the T</TD></TR></TABLE>
That's good, because I have no idea what "PF" is. Probably some proprietary Greddy fitting. PF=Probably Fucked.
Since the T is NPT, and the block is BSPT, then you need the fitting that's 1/8 BSPT-1/8 NPT.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A Grenade »</TD></TR><TR><TD CLASS="quote">That's good, because I have no idea what "PF" is. Probably some proprietary Greddy fitting. PF=Probably Fucked.
Since the T is NPT, and the block is BSPT, then you need the fitting that's 1/8 BSPT-1/8 NPT.</TD></TR></TABLE>
Nope already tried that, it didnt work I need both sides of the fitting to be NPT. Ill see today. The fitting will come in today. They told me a NPTF fitting will fit.
The threads in your block that held the oil pressure switch are 1/8 BSPT. If the T is NPT, you'd need that side to be 1/8 NPT. I don't understand?
HondaVTEC1993
11-08-2007 04:21 PM
Buzzbomb
09-30-2005 12:00 PM
SOHCEK-Turbo
05-30-2005 02:10 AM
BlueShadow
02-03-2005 08:27 AM
