GReddy sohc kit w/ internal wastegate
I have my turbo on and I just put on a boost guage and I am pushing 2lbs of boost.....how do I up my boost on the internal wastegate? or where do I hook up a boost controller?
Re: GReddy sohc kit w/ internal wastegate (QUICKERSILV3R)
You'll need to get a boost controller. Find out what's wrong with the wastegate, though. You should be at 5.5 psi on the GReddy SOHC kit.
Re: GReddy sohc kit w/ internal wastegate (Daniel)
well what about that little rod that runs out of the wastegate..I heard you can mess with those two little bolts that are on there to adjust boost anyone have pics or no which way to move the screws to add more boost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QUICKERSILV3R »</TD></TR><TR><TD CLASS="quote">well what about that little rod that runs out of the wastegate..I heard you can mess with those two little bolts that are on there to adjust boost anyone have pics or no which way to move the screws to add more boost</TD></TR></TABLE>
there ya go http://www.gamesbbs.com/~dmoore/turbo-tuning.htm
you may want to check the cat and see if its clogged. That trubo should be puting out more than 2 psi. back pressure could effect that.
yeah before you mess with the wastegate try to figure out why your not getting the regular amount of boost...
Re: GReddy sohc kit w/ internal wastegate (pornstarSR)
See if you have any exaust leaks pre-turbo. Then make sure all your charge pipes are hooked up properly.
Re: GReddy sohc kit w/ internal wastegate (Happyman)
Def. check for exhaust leaks. When i put mine on i didn't torque the exhaust mani bolts after the motor was hot. My turbo wasn't spooling till 6k ! Anyways my buddy came over and showed me how loose they were and how i didn't have my DP fully tight either. After torquing all the bolts i now spool at 4.3 k
I would check for boost leaks in the charge pipes. Also I would check with another boost gauge just to be sure.
Re: GReddy sohc kit w/ internal wastegate (t04ecvc)
yup, definatley check with another boost gauge.
i am having problems with a greddy 18g right now also.
i have infinite boost!
i am calling greddy tomorow to see if the will warrant the actuator (doubt it )
1 Post
Re: GReddy sohc kit w/ internal wastegate (Del_Slowest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest »</TD></TR><TR><TD CLASS="quote">Def. check for exhaust leaks. When i put mine on i didn't torque the exhaust mani bolts after the motor was hot. My turbo wasn't spooling till 6k ! Anyways my buddy came over and showed me how loose they were and how i didn't have my DP fully tight either. After torquing all the bolts i now spool at 4.3 k</TD></TR></TABLE>
you have a greddy 15G ? if so isnt 4.3 a little high?
*edit* i looked at your sig wrong.
Re: GReddy sohc kit w/ internal wastegate (kabaroo)
I know, i'm not quite sure what is wrong, 4.3k is in neutral which makes it higher since it doesn't have as much load on it as it would actually driving down the street. I'll look at it when i'm actually moving next time though.
br1ev8
04-06-2006 02:44 PM
