SOHC Greddy Turbo Kit users
Hey guys, I want to up the boost a bit. My question is, if I build the Home Depot special boost controller, will my wastegate still hold up to say 10 psi or so??? This is the Td04h-15g kit. Thanks guys! The other option I have heard of is cutting the wastegate actuator arm and them threading a bolt type thing on there so I can adjust the boost at the wastegate. Any thoughts on what I should do??
Re: SOHC Greddy Turbo Kit users (Ricey McRicerton)
the boost controller will allow you to do it and you will be fine as long as you don't change out the downpipe. if you do change the d/p it will spike. Secondly, you better not up the boost past like 8 or so on the blue box... it will detonate.
Re: SOHC Greddy Turbo Kit users (Johnyquest)
I'm running the E-Manage, and I do all my and my friend's tuning, so tuning for higher boost is no biggie. So just make a Home Depot special boost controller and tune it and I should be good right?? Which line do I run this in?? The line that the WG reads??
New User
did you try to adjust the wastegate? there was a site with instructions on how to do it. It was either lengthen the arm or shorten. When i get home i'll post the site for you.
New User
Re: SOHC Greddy Turbo Kit users (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">http://www.gamesbbs.com/~dmoore/turbo-tuning.htm
thats the one
thats the one
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: (rota92)
yeah, that's how I did it. I just tightened up the actuator arm to the wastegate. Use this for reference (got it from a turbod16.com member):
- 7-8 psi is exactly halfway down the threads of the actuator arm
- all the way closed is 10.5-11 psi on the greddy turbo
- 2 threads showing is 10 psi exactly on the greddy turbo
Hope that helped. I'm currently running 7 psi, going to up it to 10 psi when I get my clutch, fuel pump and injectors.
how d i do that with my t3 42/48 ar.? it's set at 5 psi right now. theres a nut on the wastegate arm, i tried to loosen it but the actuater arm gets longer. When i test drove it, lookin at my boost gauge, i was only boostin 3-4 psi..put the bolt back to were it was and tried to go further, but thats was the max. are there ways to get this turbo to run 7-8 psi?
Re: (flat-blk-HB)
Muthafucca, Man I sent you the ****** payment. It may not get there yet or it can be my part that i screwed up on the addy, But don't ****** tell peeps I screwed you. But iain't sendin you another 50 bucks *******. I already did, I even got the detachment of the money order i sent if you don't believe me. You gonna start actin like a bitch then be it, that's exactly what you are. Be a real man and talk to me about this problem without being a punk about this. aight?
Re: (LbcJiGGa)
Chill the **** out...I have called like 3 times in the past 2 weeks and nobody at your house must be taking messages like they say or something..You said it was sent out on a Sunday of last week..I know it does not take that long to get here........
