Greddy profec A or fuel problem.
Old Sep 9, 2003 | 08:13 AM
turboex's Avatar
Default Greddy profec A or fuel problem.
Heres my deal, sr20det stock turbo internal wastegate. The stock wastegate is set to open at 7psi, and it does this fine. If i pull the hose of the wastegate it will go to around 22psi. Now heres the problem, when the car is in first gear and i punch it with the boost over 15psi (via greddy profec A)the car will pop and miss at 14psi. However when i run in second gear the boost will fall to 10psi and not hold 15psi. and in third it will hold what ever psi i set the profec at. any ideas guys?
bboygreddy
Aug 3, 2007 12:19 AM
whackassfawker
Aug 11, 2004 07:27 PM
maddog20
Aug 4, 2003 03:07 AM
Kevin
Nov 18, 2002 10:05 AM
GorData
May 14, 2002 07:19 PM
