I have a everything hooked up right and a 8psi spring. My problem is I'm getting more boost in higher gears and at the upper rpms. I've been trying all different settings and no luck yet. Any ideas would be great. Here's my low settings.
0 %
10 % gain
6 psi start boost
11.5 psi warning
0% cut limit
I'll still over boost. I want to set it up for 8psi low boost which is stock boost and 12psi on high boost. If I shut it off it still overboosts. Disconnected it holds boost perfect.
Modified by e'sd16 at 12:52 PM 8/5/2004
0 %
10 % gain
6 psi start boost
11.5 psi warning
0% cut limit
OG triple OG
usually if your boost gets higher your gain is too high........
I've been told so many different things. I'm going to drop it to 4% which is super low. I think I might raise it to like 50 % and see what happens also. Any other ideas people. More info on my setup. I have a precision SC 44 turbo and Tial 35mm wastegate with kooks header. I'll just save time before someone asks. Oh ya its on a B18C1.
if its an 8psi spring and you want 8psi , then turbo the EBC off or keep everything set at 0. if you play with the gains you will be rasing the values.
Very true. I'm going to leave the start boost set to 6 psi and turn the gain down to 0 and see what happens.
dude, it willbe over 8 then. idont understnad your thinking
Even if I set everything to 0. I still boost past 10psi. Damn thing is making me mad.
If you turn it off, do you get the same results? Hold down the top left SELECT button for 2 seconds.
(Below stolen from some Evo folks, good info, possibly some errors. I don't think the definition of GAIN is quite right.)
http://www.srtforums.com/forum....html
Definitions and things you need to know before you start:
SET This is how you set the boost pressure. Rather than setting it in psi or kPa, the Greddy unit allows you to adjust it as a percentage value, from 0% (greddy unit essentially turned off) to 100% (greddy unit will set the boost as high as it can). This setup demands a certain amount of trial-and-error to properly configure it since you have to make adjustments, then drive under WOT (Wide Open Throttle) and see what the maximum boost pressure achieved was throughout the entire RPM range. SET SHOULD BE SET TO A CONSERVATIVE VALUE WHEN BEGINNING TO TUNE YOUR GREDDY UNIT. 30% SEEMS TO BE A CONSERVATIVE SETTING BASED ON MY TESTING AND BASED ON OTHER REPORTED NUMBERS FROM EVO OWNERS AND TAKING INTO CONSIDERATION THE LINK BETWEEN SET AND GAIN (see GAIN below).
GAIN is defined in the manual as the value to adjust the "boost consistency". You don't really need to know exactly what that means. You should set GAIN to 0 when beginning, and you will then test the car under WOT while paying attention to the boost pressure. If the boost goes up and then falls off at higher RPM, you will want to increase the GAIN by a conservative amount (5% should be relatively conservative to begin with, then when you want to fine-tune it, you can go down to intervals of 1%). When you increase the GAIN value, the corresponding boost that you will go up to will be higher even if you leave the SET value alone. GAIN SHOULD BE SET TO 0 WHEN BEGINNING TO TUNE YOUR GREDDY UNIT.
START BOOST (also known as SET GAIN because that is what is displayed on the unit when adjusting this setting) is the lowest boost that the Greddy unit will begin increasing the boost from under WOT. You want this to be as close to the SET value as possible, since you want to keep as close to your desired boost as possible. However, setting it too close to the SET value will cause the boost to spike. You should set this to a conservative setting when beginning to tune your Greddy unit. Then you can fine-tune it later to get it as close to the SET value as possible without causing the boost to spike. Fortunately, you can set this in psi or kPa, thankfully Greddy didn't decide to let this be adjustable in % like the SET value. START BOOST SHOULD BE SET TO YOUR DESIRED BOOST PRESSURE MINUS 4 PSI (about 28 kPa).
WARNING is the maximum boost that you do not want to exceed. Fortunately, you can also set this in psi or kPa like the START BOOST value. When the boost exceeds the WARNING level, it will kick in the LIMITER, which decreases the boost a certain amount that you can set. WARNING SHOULD BE SET TO YOUR DESIRED BOOST PRESSURE PLUS 1 PSI (about 7 kPa).
LIMITER is the boost percentage that the Greddy unit will lower to when the WARNING boost pressure is hit. LIMITER SHOULD BE SET TO YOUR SET VALUE MINUS 4%.
PEAK is the peak boost value that the unit has seen since the last time it was cleared. To clear it, go to the peak boost display, and hold down the set **** until the unit beeps and "---" is displayed. IT IS A GOOD IDEA TO CLEAR THIS BEFORE YOU BEGIN JUST IN CASE YOUR UNIT HAS A HIGH BOOST ALREADY RECORDED.
LAST BOOST shows you the last boost that was recorded every time the accelerator is released for 3 seconds. TURN LAST BOOST ON BECAUSE IT IS A GOOD DIAGNOSTIC TOOL WHEN TUNING YOUR UNIT.
Keep in mind that when displaying in kPa, it does not show it technically in kPa, but rather misleadingly in bars, which Greddy inconveniently tries to justify by sticking x100 kPa next to the display. Therefore, 100 kPa will be displayed as 1.00 x100 kPa. Psi will also unfortunately be displayed in psi x10 so that 19 psi will show as 190, adding to the confusion.
Another very important thing to keep in mind is that when you first power on your car or the Greddy unit, WARNING will be set to 14.5 psi (100kPa, or 1 bar) until you interact with the Greddy unit by pressing any button. This "feature" is not documented in the manual.
Also keep in mind that atmospheric conditions affect the operation of your boost controller. When it is hot, you will get different results than when it is cold. One possible way of solving this issue is tuning your Greddy unit under the "Lo" mode for when it is relatively cold, and under the "High" mode for when it is relatively hot. Unfortunately, two modes are hardly enough for somebody that needs to account for very different summer and winter climates, and also for more aggressive settings for when increased performance is desired.
The maximum boost that you will see is also not consistent throughout the gears, which adds even more to the confusion. Unfortunately, if you've already increased your start boost to the maximum setting that doesn't give you surging, then there seems to be no way to get around this variance in boost pressure from low to high gears. I don't know if this is a limitation of the greddy unit specifically, or if it's something inherent to electronic boost controllers in general. The only two things that you can do to compensate is the following:
1. Set it to the "safest" of the settings that does not trip your limiter. To do this, tune the unit to your desired boost pressure in fifth gear.
2. Tune the "Lo" and "Hi" settings corresponding to having the boost maximized during the low gears and during the high gears. This would require you to manually hit the button to switch to the "Hi" setting when you shift to third gear or whatever you started tuning your "Hi" setting at. This is why Greddy makes the wireless remote switch that straps to your steering wheel to switch between "Hi" and "Lo" settings.
The following steps should be taken in exactly this order, taking into consideration all of the previous information:
1. Change boost pressure units to psi if so desired (see manual).
2. Set WARNING to your desired boost pressure plus 1 psi (about 7 kPa) (see above).
3. Set START BOOST (SET GAIN) to your desired boost pressure minus 4 psi (about 28 kPa)(see above).
4. Clear PEAK boost value (see above).
5. Set LAST BOOST to ON (see above).
6. Set GAIN to 0 (see above).
7. Set SET to 30% (see above).
8. Set LIMITER to SET minus 4% (26% if you followed #7).
9. Test for boost falloff at high rpm. You should probably do this in a wide open area with no other cars nearby and preferably no cops. It is also good to have somebody in the car with you that can watch the gauge while you concentrate on not wrecking your car. If there is no boost falloff, then go to #10. If there is boost falloff, then increase the GAIN by 5% and test again. Keep in mind that when you increase the GAIN value, the corresponding boost that you will go up to will be higher even if you leave the SET value alone. Repeat until the boost pressure does not decrease, or until you feel surging. If you feel surging and the boost pressure still decreases (not sure if this is possible) then decrease to the last level that you did not feel surging at.
10. Increase SET by 2% and adjust LIMITER accordingly, then test again. Keep increasing by 2% until desired boost level is obtained.
11. Increase START BOOST (SET GAIN) by 1 increment and test until surging is felt or the WARNING level is hit and the display turns red, then decrease to the previous setting.
Once you have followed these steps, you will have roughly tuned your unit. To fine-tune it, repeat steps 9 and 10 except this time only increase or decrease by 1 increment.
Here are some number that some of the people on the board are using.
I would start from the base and work from there. Every car will be different.
My low setting is at 15 psi, with no dropoff. I have the Rage WGA with the 12-15psi spring. I usually run with my low setting on the street or turn my EBC off. I currently hold 14 psi with the EBC off.
LO--
Set Boost: 30%
Gain: 20 psi
Set Gain: 23 psi
My high setting is set at 18 and has about a 2 psi drop off. Unless you are completely in it, there is compressor surge when shifting within your low RPM range. So this setting is really completely useless for normal street driving.
HI--
Set Boost: 45%
Gain: 20 psi
Set Gain: 38 psi
LO--
Set Boost: 30%
Gain: 20 psi
Set Gain: 23 psi
HI--
Set Boost: 45%
Gain: 20 psi
Set Gain: 38 psi
I'm taking my car out for another test run tomorrow morning. I keep overboosting even with the EBC off. For tomorrow's test I've rerun the the vacuum lines. Here's my new setup thats untested.
Com to top of wastegate
Compressor side of Turbo to NC port.
Side of wasetgate has it's own vacuum source now from my Skunk2 intake.
I had the Compressor side of the turbo and side wastegate T'd to the NC port. I thought this was supposed to be the proper way to hook it up but I over boost like this. If this doesn't solve my overboosting problems I'm going to hook it like and internal wastegate. I'll just move from the NC port to the NO port.
Anyone else with similar problems and a solution let me know.
With a 30% cut limit, you'd actually be turning up the boost (from 0% to 30%!) when you hit the warning PSI. Turn at or below your set boost % (0%). Mine is set 5%/7%, limiter 0%.
That's sorta irrelevant now, good luck with the wastegate.
-Chris
-Chris
You may have just solved my problem. If thats the truth. The way I have it now is the cut limit is set so high like 80%. I thought it cut 80% of the boost. If thats the deal than that explains the nonstop over boosting because once I go past the limit it trys to set it at some outragous boost abount. 80% would be like 20 psi
I'll set it to 0 and see what happens.
I'll set it to 0 and see what happens.Still overboosting. This thing is driving me nuts. I disconnected it and held 10 psi. I'm going to pull my mbc out of my other car and try that unless someone has a solution to my overboosting problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e’sd16 »</TD></TR><TR><TD CLASS="quote">Still overboosting. This thing is driving me nuts. I disconnected it and held 10 psi. I'm going to pull my mbc out of my other car and try that unless someone has a solution to my overboosting problem.</TD></TR></TABLE>
dood i hate my spec 2...
biggest waste of money in my opinion...
im sticking to an old fasion dual stage mbc.
ive ran into the same issues your having...
my wastegate spring rate was good for 8psi and i was trying to run 8psi...
i set my gain to 0%, start boost to 6.5psi, and that was it...
and i was making like 11psi...
oh well i dont run it any more...
infact its for sale.
I could not get mine to work either... but I signed up for this thread because ccfries gave out some good info... thanks!
Ya that was very informative of ccfries. I still can't get the thing to stop over boosting.
Modified by e'sd16 at 7:05 PM 8/7/2004
Well Its diconnected now and what do you know. No more overboosting.
