Greddy Profec B is awesome!
Old May 24, 2002 | 01:15 PM
austrian type-R's Avatar
Default Greddy Profec B is awesome!
I have ditched the Apexi AVC-R, cause I was not able to get constant boost and I realy hated to adjust the boost with the feackin duty cycle setting percentes. This kinda sux!
Th eGreddy Profec B is so easy to set. One thing I miss a bit is the gear dependend boost setting of the Apexi, but when I do DRAGing, I will press the select button on the Greddy from low to high boost after I switch into 3rd gear.
PS: I could experiment with both controllers, just hook them up in line
Old May 24, 2002 | 01:17 PM
turbopanda's Avatar
Default Re: Greddy Profec B is awesome! (austrian type-R)
does the boost swing at all with the profec B? does the boost come fast too?
Old May 24, 2002 | 02:12 PM
Default Re: Greddy Profec B is awesome! (turbopanda)
I don't know exactly, but it seems to be similar.
Old May 24, 2002 | 02:43 PM
VaporTrail's Avatar
New User
hence why I usually recommend the profec B.
Old May 24, 2002 | 08:40 PM
00ITR #543's Avatar
Did you tap the charge pipe before the throttle body like in the directions when you hooked up the profec b? I have heard that you don't really have to do that. Has anyone tried hooking it up both ways? Which way gives more consistant response?
Old May 25, 2002 | 10:05 AM
Default Re: Greddy Profec B is awesome! (00ITR #543)
I have kooked it up at the compressor housing @ the turbo, like my AVC-R was. Pretty constant boost....go to Greddy.com and download the instruction...the charge pipe is mounted at the compressor side of the turbo there, while in the instruction of the Greddy Profec B box is before the throttle body.
Old May 25, 2002 | 10:24 AM
jinxproof99's Avatar
New User
don't wait till third to hit that button. hit it in second.
proud supporter of profec B.
Old May 25, 2002 | 11:29 AM
lucas569's Avatar
Default Re: Greddy Profec B is awesome! (jinxproof99)
funny scc rated the profec b better than the the profec a! glad i bought the b.
Destructive-
Sep 2, 2008 09:44 AM
LSej1
Jun 3, 2008 09:41 AM
hovic
Mar 16, 2005 01:19 PM
skilzz
Oct 24, 2002 03:37 AM
DIRep972
Aug 5, 2001 07:51 PM
