Greddy Kit- Running lean help!
Old Nov 17, 2005 | 01:50 AM
whteteg8901's Avatar
Default Greddy Kit- Running lean help!
i finally installed the greddy kit this sunday and had the car running well for about 1 day then the check engine light goes on when my gas was near empty.
Later on that night while warming it up i smell gas and find out the injector closest to the distributor is leaking from the top since the o-ring was cracked. I replace it and everything was fine again for 1 more day. Then today check engine goes on and the same injector starts leaking again bcuz the oring cracked again.
diagnostic results...
fuels system too lean
fuel trim malfucntion
any ideas? i thought the greddy kit was set to run rich to be on the safe side
Old Nov 17, 2005 | 04:00 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Greddy Kit- Running lean help! (whteteg8901)
you need to stop shredding oring, you have a pressure loss from the oring, and your ecu is trying to compensate. use some 2+2 when you are installing the injectors into the bosses. it allows the orings to slide in with no problems.
Old Nov 22, 2005 | 02:46 AM
o ring leak fixed...
now only showing p0171- running lean
car has close to 70k miles.
Just bought a new o2 sensor, and fuel filter, retarded timing by 2 deg. hopefully the code will go away.
Injector wires were not soldered. Will this have something to do with the car running lean?
thanks!
Old Nov 22, 2005 | 01:15 PM
Old Nov 22, 2005 | 01:43 PM
BoostR41's Avatar
what is the fuel presure at the rail? could you be blowing the o ring out because of too much presure?
Old Nov 24, 2005 | 11:40 PM
Default Re: Greddy Kit- Running lean help! (BoostR41)
just replaced the o2 sensor, and also the fuel filter.
System is still running lean- P0171
About to solder the injector wires and see what happens
any other ideas guys?
Old Nov 24, 2005 | 11:42 PM
y0y0's Avatar
blue box?
Old Nov 25, 2005 | 06:19 AM
MDP's Avatar
MDP
If you have a fuel pressure riser, drop the pressure.
vtecgsr98
Dec 24, 2005 11:21 AM
s2kkk
Jul 16, 2005 04:07 PM
sd_ep3
Aug 7, 2004 09:00 AM
StolenTeg
Jun 22, 2004 07:21 PM
93TurboSi
Sep 23, 2002 08:39 PM
