Greddy Kit fitment on 01 Intergras HELP!
Old Oct 12, 2001 | 09:38 AM
hybrid_eg's Avatar
Default Greddy Kit fitment on 01 Intergras HELP!
I was told that the greddy kit for GSR would not bolt on to the 01 model.. because the downpipe has to be modified (is it jus the lenght issue? too short or long) or clearance issue which i doubt is the case.. I was also told that you can run the greddy black box, and must use like a vortech FMU or something? I dont see a reason why this kit wouldnt bolt on the 01 model besides that you might have to modify your piping a bit to make it fit due to cat size being different which any muffler shop can do within minutes.. Please shed some light on this.. thanks!
Old Oct 12, 2001 | 01:33 PM
Mikex25's Avatar
New User
Default Re: Greddy Kit fitment on 01 Intergras HELP! (hybrid_eg)
well to make it fit you have to make the dp longer and the FCU might not work, because 00-01 GSR's are obd-II and Half, not just obd-II, but I think it should still work. Someone on this board did this on his 00 GSR and said he even used the FCU that came with it.
[Modified by Mikex25, 10:34 PM 10/12/2001]
Old Oct 12, 2001 | 01:42 PM
guyuenvy's Avatar
i have a 2001 gsr with greddy turbo fcu will work without a problem but u need wiring diagram for the gsr ecu because greddy doesnt supply it and the dp has to be about 3 inches or so longer. also you need to weld a bung for the o2 sensor in the dp as 01 gsr has a o2 in the header not in the cat.
Old Oct 12, 2001 | 01:56 PM
H23 Power's Avatar
Default Re: Greddy Kit fitment on 01 Intergras HELP! (guyuenvy)
all GSR's have a o2 in the header, 96+ have another in the CAT...
every OBD2 gsr has 2 o2's
vgsr
Feb 7, 2005 02:58 PM
Gecko23
Oct 26, 2002 05:35 AM
kahlua2323
May 29, 2002 10:11 PM
bhcvc
May 7, 2002 05:20 PM
boipika
Feb 26, 2002 03:22 PM
