Greddy Full auto turbo timer.
Old Apr 15, 2006 | 05:11 PM
UnKnOwNsLeEpEr's Avatar
Default Greddy Full auto turbo timer.
Ok, just got the TT for my Sohc-T setup. Wired everyting up according to the Greddy manuel. Timer counts down, and shuts Head unit off. The problem, when the TT and head unit shuts off, the engine is still running. WTF is wrong? Ne opinions? Thanks ahead and LMK.
Old Apr 15, 2006 | 05:20 PM
komat's Avatar
Default Re: Greddy Full auto turbo timer. (UnKnOwNsLeEpEr)
its not hooked up correctly
check your wiring again
Old Apr 15, 2006 | 05:24 PM
Default Re: Greddy Full auto turbo timer. (komat)
Uhm...yep, double, triple, and quadripled checked. Blue to white with black stripe, Green to black w yellow stripe. Red to fat white 12v wire. Brown to Ebrake wire, and Purple to speed sensor wire. No luck. I think my TT is *****.
Old Apr 15, 2006 | 07:25 PM
Soccerking3000's Avatar
did you set the switch on the back correctly? my greddy TT will keep the car running but every other accessory turns off including the head unit while it counts down, so something isnt right with yours...
Old Apr 17, 2006 | 06:33 AM
Default Re: Greddy Full auto turbo timer. (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">did you set the switch on the back correctly? my greddy TT will keep the car running but every other accessory turns off including the head unit while it counts down, so something isnt right with yours...</TD></TR></TABLE>
Yeah, when i set the swithc to the Far right, it counts down, the ebrake check works, shuts off but the motor doesnt, when i set the switch to the right, the TT doesnt count down, doesnt switch off, keeps head unit on and the motor shuts off as soon as i turn off the ignition. Dayem. What a hassle.
da_ska
Jun 5, 2009 04:33 AM
Metzler
Oct 24, 2005 07:27 PM
Threads
Jun 7, 2005 04:13 PM
ham
May 5, 2005 04:22 PM
Infinity_Racer
Apr 2, 2003 05:52 PM
