need help on full auto greddy turbo timer
i have just installed the full auto greddy turbo timer. i have the device working and connected correctly base on searches i did on the web. i was wondering if anybody know how to set the turbo timer to its basic feature which is having the car idle while the key is out. for sum reason iam having difficulties making this work. need help.plsss
Re: need help on full auto greddy turbo timer
check wires.. im guessing either the constant pos wire isnt hooked up correctly... i forgot if the greddy timer needs the e brake wire hooked up also so double check that.. does the unit just not power on or not keep the car running with the keys out
the green wire connected to ingnition ON(black wire with yellow stripe)
the red with the large white wire on the ingnition.
the black to the the body(ground)
the brown to the e brake.
and last is the purple to the ecu. its the yellow with baby blue stripe on the second slot
the unit is on but i cant get it to count down when i take the key out and let it idle for what ever minute or sec.
DO you have a greddy full auto turbo timer, because they might have the differents with the regular greddy turbo timer?
open to any help.
i have a hks turbo timer i helped my friend with his greddy timer, they are all basicly the same.
wiring sounds right.
http://www.greddy.com/img/PHP/products/pdf/685.pdf
says
while car on ebrake up.
press power+select
press time to increase by 10sec
says
press power+select
