Greddy E Mangment BIGEST Injector U can use on it
I got stock honda injectors right now, eveything else is done, I have the e mangment unit with everything, on a d16, but i was reading the box and it said i can only take up to %150 bigger then stock injector? Thats only a 360?
Whats the most someone on a honda with a D series has run in size on injectors runing the E mangment unit?
Also should i go with 440cc or 550cc i bet they would work fine, u can change the setting to run almost any size, 550's would be nice if they can run on the unit, becuase when i change turbo i hoping at around 300hp when i get the cash to build the motor. The E mangment looks cool, becuase u can set how much u want to run on the injector if u have 440'cc u can run 280cc if u want, witch is kinda cool, might as well get the 550's for furture upgrades, but can the unit support them?
Re: Greddy E Mangment BIGEST Injector U can use on it (Quad-Damge)
I had 550's with my e-manage, and my car wouldn't run. It would start but wouldn't run, if you catch my drift. Let me know if you have any questions
Re: Greddy E Mangment BIGEST Injector U can use on it (AZMRSi)
Tuned an E-manage with 550cc with no problem, runs great and idle decent with 12.2 A/F on the dyno full boost.
Greddy techs told me it can control up to 150% larger than stock injectors.
Re: Greddy E Mangment BIGEST Injector U can use on it (NIAScrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NIAScrew »</TD></TR><TR><TD CLASS="quote">1000 cc np</TD></TR></TABLE>
I don't know about that...doubt it
Re: Greddy E Mangment BIGEST Injector U can use on it (Paul_Vang)
local tuner runs 550 and 660cc injectors on all the e-manage cars he does. I have 550's personally.
Re: Greddy E Mangment BIGEST Injector U can use on it (turbodGSR)
Good ****, i might get some 550cc
should i get peak and hold?
i was thinking sats would be the best for a small D series turbo
not to threadjack but i have been wondering about the injector change feature also. when i go to put larger ones in, the emanage uses the AFM map to accomodate the larger injectors, correct? will this scaling back of the MAP sensor voltage to accomodate the bigger injectors toss my timing way advanced? never seen this covered anywhere.
Re: (guido-kp)
Yes other people have been reading up on that, The E mangment Looks like a great unit, i did alot of reserch but not many people run the thing, so it's hard to find info about it
