Greddy E-manage ULTIMATE
Old Oct 24, 2005 | 10:32 AM
  #26
2k.civic.si's Avatar
Default Re: (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKingPin &raquo;</TD></TR><TR><TD CLASS="quote">
OBDII-OBDI conversion......not hard at all - not time consuming - not expensive...........whats the problem?</TD></TR></TABLE>
if your going to convert to obd1 then its stupid to use something like e-manage...might as well go hondata, crome or uberdata...much better
Old Oct 24, 2005 | 09:18 PM
  #27
Smokinsax's Avatar
The Boot
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">Should work on anything. My Supra is OBD0 if I recall and I have it on that</TD></TR></TABLE>
Old Oct 24, 2005 | 09:21 PM
  #28
.dave's Avatar
i HAS questions ?
Default Re: Greddy E-manage ULTIMATE (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Im surprised they are still investing money to develop products like this. Why not just improve the current E-manage's crappy software?</TD></TR></TABLE>
I don't think the old e-manage let you mess with ignition maps. I could be wrong though.
Old Oct 25, 2005 | 05:59 AM
  #29
PM-Performance's Avatar
Default Re: Greddy E-manage ULTIMATE (daveG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think the old e-manage let you mess with ignition maps. I could be wrong though.</TD></TR></TABLE>
It does, but not with the same resoltion. Also the Blue doesnt have all the functions the Ultimate has. The ultimate can be compared to a Hondata type unit now with function. Maybe even more function.
Old Oct 25, 2005 | 07:42 AM
  #30
bluemax189's Avatar
Default Re: Greddy E-manage ULTIMATE (itr206)
yeah, ill be going with the ultimate soon, i got obd2b, and i would go with uber or chrome, but no tuners here, and im not buying a new ecu, conversion harness, and burners and chips. also, its a bitch for anything else, because you got to open up the computer and desolder and solder stuff in there. i dont trust myself with a car that i need to drive everyday. i cant afford to have my car out of commission for even a day. also, in MD, the emissions on obd2 and above they dont even have your engine running. they just hook up to the obd port and turn the electric on. i dont feel like switching ecus just to do emissions, i rather just keep my obd2.
Old Oct 25, 2005 | 07:45 AM
  #31
abmerop18's Avatar
its simple, they want to make more money. they wont make as much money by just upgarding the software as they would by creating a whole new product
Old Oct 25, 2005 | 07:48 AM
  #32
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
all you gotta do is convert to obd I </TD></TR></TABLE>
Yea.but legally pass inspection with a turbo? awsome.....for ny they don't do sniffers. So eliminate the second 02 sensor, and use this managment...basically you can have a fully tuned and LEGALLY inspected obd2 car. pretty cool in my book
Old Oct 25, 2005 | 05:20 PM
  #33
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: (m R g S r)
whats the booost set at for the 19t turbo kit? 6.5?
Old Oct 25, 2005 | 06:23 PM
  #34
kappa13's Avatar
Default Re: (BrokeAssPinoy)
Well i see that everyone is undecided on what ECU is better. I just want anyone's professional opinion, I have a 99 si which is OBDII and i know that in order to use hondata you need to convert to OBD 0 or I. Now being that I live in NC for the time and they are starting the whole emissions check through the OBD II hook up, I dont see a way i can use Hondata. So can anyone highly recommend an ecu i can use with the OBD II. I am planning on installing a full race turbo kit here soon and I want to get the ECU once i install so It can be tuned properly and so I can get the power levels I want to achieve. If anyone can point me in the right direction I would appreciate it.
Old Oct 25, 2005 | 07:10 PM
  #35
Eddiebx's Avatar
Default Re: (Das Schmoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">I agree that the existing emanage is a buggy piece of hardware that needs some major work. I had the emanage for a while, but the 2 hour install because of confusing instructions, constant CEL's even though it was hooked up correctly, extra expensive software for fine tuning required, extra bogus harnesses, and OBD2 learning around the fuel maps caused me to sell it a month later. I have too heard the great success of other cars using the Emanage, but the Honda crowd may not be embracing them due to the problems I have encountered.
Now I have Crome in an OBD1 ECU, it runs like a champ, is more finely tuned and doesn't throw CEL's.</TD></TR></TABLE>
the old emange works flawlessly, and does exactly what it was meant to do. if you were having problems with it, then its most likely install/user error. unless of course you had a defective unit. i've installed and tuned a few of them and never had a problem with it.
Old Oct 25, 2005 | 08:39 PM
  #36
TheShodan's Avatar
Moderator
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
the old emange works flawlessly, and does exactly what it was meant to do. if you were having problems with it, then its most likely install/user error. unless of course you had a defective unit. i've installed and tuned a few of them and never had a problem with it.</TD></TR></TABLE>
I agree. I've never had any problems with the E-manages that I've used and assist tuning also. 2 cars on e-manage and not one issue.
AzN_Flava
Apr 26, 2005 12:16 PM
nkkeisuke
Nov 20, 2004 09:05 AM
Civic92Turbo
10
Jul 13, 2004 11:52 PM
streetlvlhatch
Dec 29, 2003 11:34 AM
TurbothisLS
Dec 12, 2002 09:55 AM
