Got some questions for you turbo junkies
I'm currently running CTR pistons in my 94 GSR with a CTR intake cam and stock exhaust cam. My question is, is it safe to attempt to turbo this setup? I read on the board that you can install a thicker head gasket to lower the compression, but is that okay to do and then turbo?? I've also got a V-AFC, will I have to upgrade to a Hondata ECU? One more question, if I were to turbo, would it be best to run with the stock GSR cams? Thanks for any advice.
Location: Toronto, Canada currently residing in ATL, GA, USA
Re: Got some questions for you turbo junkies (rewsnaeht)
Anything is possible with the right amount of tuning. Topfuel amkes a turbo kit for the CTR.
Re: Got some questions for you turbo junkies (Apex i ITR)
