got code 72: cylinder 2 misfire
Old Nov 7, 2001 | 07:44 AM
Flamenco-T's Avatar
Default got code 72: cylinder 2 misfire
my plugs were bad, there was a small hint of white spot, from what I understand, it indicates a detonation from JBSadler.
I need to replace the plugs as it looks very bad, black carbon deposit with white spots all over it...
I was running rich ever since the turbo went it which is about a week and a half ago.....and I replaced the stock plugs with 7 series NGK about a week ago, and ever since then I was still running rich....
anyone have that problem..???
Old Nov 7, 2001 | 08:07 AM
dustin's Avatar
Default Re: got code 72: cylinder 2 misfire (Flamenco-T)
Are you sure you installed everything in the kit right?
I would have art or mark look over it
Old Nov 7, 2001 | 08:17 AM
Flamenco-T's Avatar
Default Re: got code 72: cylinder 2 misfire (dustin)
Well, I had several exhaust, boost and fuel leaks...
but there' all have been fixed so far....(I didn't install the O-ring on the wastegate flange) as of now, the car is running a lot better and quieter but I can still hears a bog on the exhaust muffler tip.....
I am ordering a set of new plugs, hopefully that'll solve the problem....
while we're on the subject, I checked with local source, they have BKR7E-VX11
will this work ? I believe the ones I got from Ben is the BKR7E-I11...I may be wrong, I am gonna check my plugs again..
TIA
stan
Old Nov 7, 2001 | 12:47 PM
Flamenco-T's Avatar
I re-gapped the plugs ( I was at .36mm ) and resetted the battery....
drove it for half an hour and bam...the CEL is on again....code 72.
I am going to order the spark plugs, but if the CEL is throwing a code 72 again after a new plugs, then I wouldn't know what to do...
Old Nov 7, 2001 | 01:00 PM
immortal's Avatar
Banned
i got all my CEL 71 72 73 lights when my head gasket was leaky ....then it finally blew out.
hehe
Old Nov 7, 2001 | 01:23 PM
Flamenco-T's Avatar
Default Re: got code 72: cylinder 2 misfire (immortal)
the head gasket blew out or the cylinders blew out ?
SimplyTron
Oct 24, 2007 12:00 PM
91 lude si
Sep 6, 2004 04:29 PM
buda18
Jul 29, 2004 09:47 PM
kinvid22
Mar 15, 2004 09:09 AM
sagaprelude
Sep 6, 2001 08:55 AM
