got a challenge for u guys!
Old Nov 12, 2002 | 01:15 PM
SpoolnG2's Avatar
Default got a challenge for u guys!
ok..i have a 255lph intank..12:1 fmu (i know thats to much)..RC 370cc injectors. yesterday i just installed a msd inline fuel pump. and now when i get to v-tec the car just boggs out and barely runs. what is the problem? before i punch it and hit v-tec the car runs fine. b/c at only like 14% throttle it doesn't do it. is it just dumping to much gas? or what?? i have a 6:1 disc on the way. just wondering if that is my problem. help me out please..very annoying
Old Nov 12, 2002 | 01:18 PM
Canuk_SiR's Avatar
Default Re: got a challenge for u guys! (Jtsintegra)
If you're dumping out black smoke when you hit WOT, then you're getting way too much fuel.
Why would you need that much fuel pressure/flow? The in-tank should supply enough fuel
Old Nov 12, 2002 | 01:22 PM
SpoolnG2's Avatar
Default Re: got a challenge for u guys! (Canuk_SiR)
i was told u should always have a inline with a fmu. and the fuel pressure will be at like 106psi
Old Nov 12, 2002 | 01:23 PM
salt's Avatar
I had a stock fuel pump and a MSD inline fuel pump. My fuel pressure was set at 45. I removed the stock pump and inline pump I replaced it with the medium walbro pump. My fuel pressure read about 40 with that setup. I turned it up to the 45 psi that my hondata was tuned at, and my car ran great. I imagine your running quite rich, but I've never run with a FMU.
steve
Old Nov 12, 2002 | 01:29 PM
Canuk_SiR's Avatar
you're really giving your injectors a pounding if you're pushing 100+ psi through them. Anything up there is just asking for a seized injector
Old Nov 12, 2002 | 01:32 PM
SpoolnG2's Avatar
what?? on a drag kit with 7 psi a stock injector pushes about 124psi through. so why is 100 psi bad for an rc injector?
Old Nov 12, 2002 | 03:24 PM
hXc-DC2's Avatar
*Bump 4 a Friend*
Whats up Josh, this is Matt. You better have that beast running when I'm back from school for Thanksgiving.
I always thought your car ran a little rich, maybe if u get like a 6:1 disk with the 370's ( I think thats what u said u have ) then it should run a lot better. i dont know a whole lot on this fuel crap but that sounds like it should work.
THR WHAT!?
[Modified by CivicEX98*, 6:33 PM 11/12/2002]
Old Nov 12, 2002 | 05:27 PM
tony1's Avatar
Default Re: got a challenge for u guys! (CivicEX98*)
the 12:1 regulator is designed to be used with a high pressure inline pump and stock injectors. Your injectors are too big, this is the problem...
Old Nov 12, 2002 | 05:47 PM
DIRep972's Avatar
Smarter than you
Default Re: got a challenge for u guys! (tony1)
the inline is allowing u to run higher pressures now and u r running too rich most likely. i think the 6:1 disk will solve ur problem.
ITRpwrdEG
Jul 2, 2004 02:35 PM
SIK IN DA HED
Nov 12, 2003 09:37 AM
importimage
Jul 11, 2003 03:45 PM
wrXtian
Jan 20, 2003 07:49 AM
zojirushi
Sep 30, 2002 11:00 AM
