got a ? about wasted gaters
waste gates mang jk. trying to decide between the 38mm and 44mm. is there a real difference? i have the blowzilla turbo on a build ls engine. goal right now is 5000-600hp. thanks for the help guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL »</TD></TR><TR><TD CLASS="quote">how low are you planning on running the boost?
do you have shitty placement of the wastegate on the manifold? or is it good?</TD></TR></TABLE>
i want to run it pretty high...and as far as placement goes how does it need to be placed? i have not bought a turbo mani yet because im deciding between the two wastegates....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION »</TD></TR><TR><TD CLASS="quote">
i want to run it pretty high...and as far as placement goes how does it need to be placed? i have not bought a turbo mani yet because im deciding between the two wastegates....</TD></TR></TABLE>
size ofthe turbo? i'm not familliar with the blowzilla lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION »</TD></TR><TR><TD CLASS="quote">its a little smaller than the t3/t04 or the t40</TD></TR></TABLE>
38 will be fine with good placement
44 for a not so well placed manifold
not sure a t3/4 will get you 5000hp though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL »</TD></TR><TR><TD CLASS="quote">not sure a t3/4 will get you 5000hp though
lol i cought that one too
</TD></TR></TABLE>lol i cought that one too
?? its quite a bit larger than the t3/t04e series.
the blowzilla is a t3/gt40, it has a 61.4mm GT35R compressor wheel and a stage 3 or stage 5 turbine wheel.
38mm wastegate might work, but its tough to say. wouldnt want to see you try a 38mm gate and have it creep. i think if you have no intention of running less than 13-14psi you will be ok. just a guess lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION »</TD></TR><TR><TD CLASS="quote">wait so i can boost like 35 psi on a 38mm wastegate? i guess i just dont understand wastegates.</TD></TR></TABLE>
larger wastegates are for lower boost larger engines
or if you wanted to control very low boost in 1st gear to high boost in top gear on a smaller engine
etc etc
etc etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport »</TD></TR><TR><TD CLASS="quote">
38mm wastegate might work, but its tough to say. wouldnt want to see you try a 38mm gate and have it creep. i think if you have no intention of running less than 13-14psi you will be ok. just a guess lol.</TD></TR></TABLE>
if that is the case, run a 44mm
turboedc2
May 20, 2005 12:57 PM
SpeedingHatch
Apr 20, 2005 09:25 PM
