Good oil return line material?
Old Jun 5, 2002 | 01:48 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Good oil return line material?
er... my kit came with a rubber hosey. Like.. came with a maxrev kit.
I imagine it would be wise to upgrade it to stailess steel braided line?
Old Jun 5, 2002 | 01:55 AM
ceemarun's Avatar
Default Re: Good oil return line material? (Snafu-Si)
yeah, i want to know the same thing cuz the earls stuff all costs a total of ~$100 for everything. rubber high-temp hoses seem so much cheaper.
Old Jun 5, 2002 | 02:15 AM
degradated's Avatar
New User
Default Re: Good oil return line material? (ceemarun)
I hope you didn't get into the world of turbo and not expect to pay an arm & a leg for everything....
Yep, stainless steel, and with the good fittings you are at ~$100.
Old Jun 5, 2002 | 03:54 AM
GruvyTune's Avatar
New User
aeroquip socketless hose with some fyrejacket over it!
Old Jun 5, 2002 | 03:53 PM
Snafu-Si's Avatar
Default Re: Good oil return line material? (GruvyTune)
$100 bucks just for one stainless steel oil return line?? man..that sucks. But worth it right?
Old Jun 5, 2002 | 04:09 PM
RoaringTurtle's Avatar
New User
yes its worth it
from day 1 i had a small leak on my rubber hosed oil return line
i dont want to even get started with the headaches it costed
spend the 100$, ask questions later
as we speak im upgrading the rubber hose to a steel braided line
its totally worth the money
take it from me
[Modified by RoaringTurtle, 1:10 AM 6/6/2002]
Old Jun 5, 2002 | 04:17 PM
GSRwBOOST's Avatar
I used garden hose and some hose clamps..
Old Jul 8, 2002 | 06:37 PM
Snafu-Si's Avatar
Default Re: Good oil return line material? (GSRwBOOST)
Your kidding right?
Old Jul 8, 2002 | 06:56 PM
JMinSi2000's Avatar
1 -10AN 90 degree fitting = $25
1 -10AN 45 degree fitting = $25
1 1/2"NPT to -10AN fitting = $6
1 -10AN weld on bung =$6
1 ft of ss line = $6
That totals up to $68...expect to pay this plus or minus about $10.
Mine was about $75 shipped for everything.
[Modified by JMinSi2000, 3:57 AM 7/9/2002]
Old Jul 8, 2002 | 07:41 PM
ion_four's Avatar
Default Re: Good oil return line material? (JMinSi2000)
Dude that is WAYWAYWAY too much to pay for that. Find an aeroquip dealer under hose and fittings in the phone book, my feed cost $35 and the return should be less. It was SS Teflon core with all the fittings. Earl's are the same **** but cost a ton more cause they're perty.
Old Jul 8, 2002 | 08:30 PM
BoOsTeD_eK's Avatar
Default Re: Good oil return line material? (ion_four)
why...would the rubber hose ever mess up if you put it on right and no leaks were present from the beggining?
Old Jul 8, 2002 | 09:01 PM
PrecisionH23a's Avatar
Default Re: Good oil return line material? (BoOsTeD_eK)
heat from your downpipe/turbo can end up burning the hose, once it happened to me once i used a heat insulation wrap on it, now im going to the earl's fittings for the return line, it may be $70, but its worth it.
Old Jul 8, 2002 | 09:23 PM
Etylorcen's Avatar
Default Re: Good oil return line material? (GudeH23a)
The steel braided line doesnt cost you much its all the fittings that do.
Old Jul 8, 2002 | 09:47 PM
reXem's Avatar
Default Re: Good oil return line material? (Etylorcen)
Is SS Line able to make a tight S Curve? or is it worse that neoprene hose?
Old Jul 9, 2002 | 12:45 AM
Snafu-Si's Avatar
That's what I was told by people as well so I'm not going to risk it. Do it right or not do it at all is what I say.
boostedBLUfg2
Apr 12, 2011 06:46 AM
birz
Jun 4, 2004 06:03 AM
B18 CYA
Apr 21, 2004 04:34 PM
r7
Jul 10, 2003 12:15 PM
Snafu-Si
Jul 2, 2002 07:58 AM
