Good or bad idea??
Old Aug 17, 2004 | 08:46 PM
HS2G's Avatar
Default Good or bad idea??
Hey guys I'm just wondering is it a good idea to boost a stock 99 civic CX with only 30k miles? Or should I jus swap a b16a2 (Believe its an SI motor) in instead? Looking for about 8-10 psi of boost and around 3000 to spend. with a hondata tune from elite in minneapolis.
Old Aug 18, 2004 | 08:20 AM
CalGSR99's Avatar
Default Re: Good or bad idea?? (HS2G)
I'm sure its ok to boost with 30k miles on the engine. IF you only have 3k just boost you CX. What do other people think?
Old Aug 18, 2004 | 08:23 AM
B18C1CYA's Avatar
Default Re: Good or bad idea?? (CalGSR99)
well check this out https://honda-tech.com/zerothread?id=940041
this would be the best option for you if you want a swap and turbo
Old Aug 18, 2004 | 08:27 AM
RyanEJ8's Avatar
With a $3000 budget your best option is to turbo the CX.
Old Aug 18, 2004 | 09:10 AM
95stangkillah's Avatar
Is the CX the one with 70hp? well regardless, even at 105 hp, the turbo ain't gonna do much for you.
play with a swap first instead.
Old Aug 18, 2004 | 09:12 AM
B18C1CYA's Avatar
Default Re: Good or bad idea?? (95stangkillah)
that swap i posted , check it out its worth the extra 500 bucks
boost4cheap
Sep 2, 2008 08:22 PM
chinopr24
19
Jan 11, 2008 05:11 PM
sohc_coupe24
Oct 18, 2005 10:53 PM
EG_Civic_Si
10
Sep 4, 2004 10:49 PM
DXturbo
May 6, 2003 08:09 AM
