golden eagle sleeves
Old Nov 25, 2008 | 11:05 AM
avotegra's Avatar
Default golden eagle sleeves
damn why someone lock my thread........i was about to explain. My block was the old sleeves, wonder if they have warrenty for that....
Old Nov 25, 2008 | 11:07 AM
avotegra's Avatar
i know you guys that like the sleeves gets all mad because of this. But i just want a answer....all i was asking was..is decking the block ok.....i dont want to spend to much money on it...
Old Nov 25, 2008 | 11:21 AM
Schister66's Avatar
Man U FTW
I was the one who locked the thread. If you would have looked back at it, you would have seen this response. Working with Golden Eagle in private is the best way to get this problem solved. Not many people want to help you if you're going to drag their name through the dirt. I understand this problem is frustrating for you, but the only person that can do anything is GE...
Quote from the last thread that you should have read.
Originally Posted by Golden Eagle
customer called me yesterday. he stated he had the block sleeved a year ago and that it sunk a sleeve. after asking some questions about the block to see if he bought it direct or through a distributor, so i could try and look up to see when we did the block. he then informed me that he bought it used and that he had it decked when he purchased the block. I informed him that he should not have done that and that he can send the block in, but warranty was voided. I told him to send it in. if we find that we did something wrong we would still fix the problem. He then asked me "how much it would cost to fix it if its not something we did", I told him we can resleeve it for $550.00 + shipping of around $60.00. Customer said no problem, and would send in the block. please contact us for further questions so we can get this resolved asap.
Old Nov 25, 2008 | 11:28 AM
avotegra's Avatar
I have not deck the block befor putting it in. I was saying is decking the block ok. I also ask him is decking the block ok. he say no. so i wonder has anyone in here have done it. i did not say golden eagle was bad. i might just end up sending to them. Now the othere question is. I am not looking for high hp, just about 300whp. I have a stock block. Do i save money buy just honeing that stock block, or resleeves the sleeves block.
Old Nov 25, 2008 | 11:32 AM
SD_Lurker's Avatar
HT White Ops
If its their older style sleeves its likely that you did indeed sink a sleeve. GE posted that you told him you had the blocked decked before using it. Decking the block will not fix the problem if it has a sunken sleeve.
Old Nov 25, 2008 | 11:41 AM
avotegra's Avatar
Did not deck the block befor putting it in. I just clean the surface and put the motor in. After a while i notice my oil pressure is low. Check the oil and OMG its milky, so i decide to take out the motor, to trouble shoot. Notice my finger nail gets stuck. So i decide to run a straight edge to check and sure enough one sleeves sunk..
Old Nov 25, 2008 | 11:43 AM
avotegra's Avatar
As of right now, i have done nothing to the block or the sleeves. Still waiting for othere option.
Old Nov 25, 2008 | 11:48 AM
SD_Lurker's Avatar
HT White Ops
Well according to Robert he stated that you decked the block. Maybe there was some confusion. Anyway it sucks that your gonna have to pay to have it resleeved since GE's older sleeves are junk..
Old Nov 25, 2008 | 11:51 AM
98vtec's Avatar
moderator emeritus
there is no other option. Its like you are waiting for someone to come up with a magical answer to your problem. If you sunk a sleeve, it needs to be re-sleeved. Who better to re-sleeve it then the people who did it originally?
Old Nov 25, 2008 | 11:52 AM
Blown90hatcH's Avatar
Cleaned it with a toothbrush or......
Old Nov 25, 2008 | 12:10 PM
CW-ITR's Avatar
The stock block with the stock sleeve is not able to support your quest of 300hp. So, your only option is resleeve this one. If GE practice their customer sactifation just like everybody else, they should fix this problem if indeed it is worsmanship issue. I believed they stated that. So, send in your block and hope that the problem is a worsmanship one.
Old Nov 25, 2008 | 12:12 PM
avotegra's Avatar
with carbcleaner and a blade wipe it off with towel
Old Nov 25, 2008 | 12:14 PM
avotegra's Avatar
stock with cower rod and wisico piston
Old Nov 25, 2008 | 12:15 PM
avotegra's Avatar
98vtec yep just waiting if anyone have the same problem, and how the do about it.
Old Nov 25, 2008 | 12:19 PM
98vtec's Avatar
moderator emeritus
GE already told you what to do.
Old Nov 25, 2008 | 12:24 PM
avotegra's Avatar
Too much money. I guess ill have to wait for income tax.
Old Nov 25, 2008 | 01:22 PM
redflaredcrx90's Avatar
first off what r ya plans. you got a sleeved block. and it took a **** im not sure if you doin turbo or all motor . if doing turbo you stock will make 300 hp if going turbo. SORRY FOR CAPS BUTYOULL NEED TUNNING TO GET IT.good luck double check that stock block and make sure its good
Old Nov 25, 2008 | 01:30 PM
CerealKiller's Avatar
wow, even after what GE and the moderator posted you're still on HERE wanting answers? Please just give GE a call back and get the issue taking care of.
If GE is will to re-sleeve with their new HD sleeve then its a win win situation. You get the HD sleeves at just about half price and GE gets a satisfied customer. I only hope this play out the way I just describe. Later.
Old Nov 25, 2008 | 01:37 PM
Golden Eagle's Avatar
when i talked to you on the phone you did say you had it decked but either way you bought this block used not from us from a privet party so unflinchingly it is not under any warranty. the block will need resleeved and i did quote you a price. this post should not have been made i did answer all your questions on the phone no need post about a block that who knows where it came from how old it is or what has been done to it. we haven't made the old style sleeves in over 5 years.
Old Nov 25, 2008 | 01:44 PM
srmofo's Avatar
I thought the sleeves were only warrentied for a year? If thats the case then, whats the issue? You bought the block used- no warranty, its AT LEAST 5yrs old- no warranty.....I swear, the nerve of some people....from the sounds of things GE has gone above and beyond anything I would of done for you.
Old Nov 25, 2008 | 02:01 PM
Schister66's Avatar
Man U FTW
This thread has been reported several times with good cause. If you have further issues or questions, contact Golden Eagle via PM or email. This is not something that should be on a public forum. It sucks, but that's the way things have to be. Please don't make a third post as it will be locked immediately. Thanks
MR.johnson
Jul 18, 2012 06:44 PM
4.8t
Sep 7, 2011 06:05 AM
ITR9788
Jan 10, 2004 09:44 PM
miller
Dec 16, 2003 02:30 PM
BeavisB16
Feb 10, 2003 10:37 AM
