going from high to low boost
Old May 10, 2013 | 01:30 PM
Crad67F7's Avatar
Default going from high to low boost
i bought a complete turbo kit for my D16Y8. RC 440 injectors, greddy cast manifold, borg warner GM - 4 turbo, Tail wastgate, HKS BOV, chipped P28 ECU with jump down harness, ebay inercooler and piping among all the little odds asn ends, ect.
im running a completely stock internal Y8 so i only want to run this set up on 6 psi. the previous owner of this kit was running 10 psi also on a stock Y8 engine. the ecu is tuned for this set up wile running at 10 psi.
so my question is do i need to get my car re tuned because i am running lower boost?
Old May 10, 2013 | 01:57 PM
Michael_accord's Avatar
Default Re: going from high to low boost
Your answer is no, you do not. There's no need to detune an ecu its better to actually tune it to full potential and just back boost down the ecu will compensate. So no it will run just fine ecu will compensate. Might not be 100% effective but surely wont blow nothing up or drive funny.
Old May 10, 2013 | 03:04 PM
Crad67F7's Avatar
thank you. much appreciated
Old May 10, 2013 | 03:30 PM
grumblemarc's Avatar
The Grumpiest
Exactly HOW do you plan to run only 6psi without rechipping?
BTW the ECU will NOT "compensate".
Old May 13, 2013 | 05:58 AM
kyden's Avatar
should be fine, provided the car was properly tuned. how do you plan on getting the boost lower?
Old May 13, 2013 | 04:41 PM
hardcore97's Avatar
the only way to compensate is put a different spring in the wastegate
Old May 13, 2013 | 05:32 PM
Hidenplanvew's Avatar
WHo cares about the boost level, a Dseries stock can only hold around 220whp.
Old May 14, 2013 | 03:49 AM
Discosteak's Avatar
I made 260whp with my stock internals d-series, for a long time with zero problems. other than the head lifting with the stock head bolts after about a year, replaced them with ARP's and drove it for another year until i sold it, the new owner turned the boost up way past what it was tuned to and destroyed the engine. YMMV
Old May 14, 2013 | 07:55 AM
When i say compensate i mean you dont need 10 different tune for 10 different boost levels. Tune to max power and just back from there. No need to have 3 or 10 different tunes.
Old May 14, 2013 | 08:02 AM
The Grumpiest
Really? How does that work exactly?
Old May 14, 2013 | 08:55 AM
Muckman's Avatar
Moderator in Chief
A good tuner doesn't just tune for peak boost. A good tuner should tune all load columns between 0 and target boost.
This can be done several ways, smaller wastegate spring, dialing back the boost controller or very carefully with left foot braking and throttle. Load bearing dynos make part throttle (and partial boost) tuning much easier.
barnie
Sep 19, 2010 06:33 PM
dc2king
Aug 18, 2008 09:40 AM
SloB16crxMike
Jul 24, 2006 09:04 AM
importracer3
Jan 5, 2006 10:05 AM
11secdx
Jan 6, 2002 11:32 AM
