going from closed to open loop pcv- see pics
Old Dec 14, 2005 | 01:47 PM
turbotime's Avatar
Default going from closed to open loop pcv- see pics
Ok so right now i am in the process of replacing my exh. gasket. And I took off my preturbo intake and saw all the crap my closed loop pcv was pushing through the compressor. So I want to switch to open loop pcv.
In the left side of the picture u can see my catchcan with the hose going to the preturbo intake slashcut. Can I just remove the slashcut and that hose and put a breather filter there, will that work alright? Althought highly illegal
Old Dec 14, 2005 | 02:04 PM
turbotime's Avatar
bump
another weird thing- the hoses coming off the block have some milky stuff near where the nipple is- i think its just from when i first installed them there was some condensation in the lines. If the water condensation in the lines mixed with the oil would that explain the milky stuff.
there is no milk in the oil or oil in the coolant (my first worry), also no milk in the valve cover...
Old Dec 14, 2005 | 02:14 PM
diet rite's Avatar
Default Re: (turbotime)
yeah get rid of that slash cut ASAP. Think of the vacuum force the turbo is using to suck oil(vapors) into the intake, that stuff builds up inside the compressor housing and intercooler making it less efficient and oil vapors can lower your octane rating when they mix in the CC. don't worry about the legality...if you've gone this far(turbo etc.) why not?
Old Dec 14, 2005 | 02:20 PM
turbotime's Avatar
Default Re: (diet rite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diet rite &raquo;</TD></TR><TR><TD CLASS="quote">yeah get rid of that slash cut ASAP. Think of the vacuum force the turbo is using to suck oil(vapors) into the intake, that stuff builds up inside the compressor housing and intercooler making it less efficient and oil vapors can lower your octane rating when they mix in the CC. don't worry about the legality...if you've gone this far(turbo etc.) why not?</TD></TR></TABLE>
well lets not make any mistake running the slashcut isnt a bad idea- the catchcan is baffled and the ic sorta acts as a secondary catch. Not the best but still- not like the end of the world. Just needs to be cleaned occasionally.
But now that ive taken it off and seen the amount that gets deposited i think that i would prefer running open breather.. Just wondering if running the breather directly on the can is ok...
also what about the milk in the lines? condensation and oil?
Old Dec 14, 2005 | 03:35 PM
turbotime's Avatar
BUMPO
Old Dec 14, 2005 | 05:48 PM
onePOINTsix's Avatar
for teh pcv you can alway do a slash cut tube in your downpipe. we did that on my friends 240... i think the slash cut pulled like 7-15in/hg at wot
Old Dec 14, 2005 | 05:55 PM
turbotime's Avatar
yeah i want to run a slashcut in the dp but i dont have the required welding tools.
Ok so I just want to put a breather on the nipple where the slashcut is right now- can i do that , is it safe and whatnot?
Also I just emptied out my can- there was all this CRAP in it like greenish milkyish **** that smelled like gas- this normal blowby crap?
thx!
Old Dec 14, 2005 | 06:50 PM
turbotime's Avatar
up
Old Dec 14, 2005 | 07:11 PM
GS-R Civic's Avatar
i have a question, i am about to install my turbo and run a similar et up, except i was going to run the hose from the pvc valve on the valve cover to the catch can, then the other hose to the intake. But i see that yours is set up different. You have two hoses going down to the back of your block and a fliter on your valve cover. What is the difference between how you are running it and how i plan to?
Don't mean the thread jack, just thought that it was a similar question.
Old Dec 14, 2005 | 07:17 PM
turbotime's Avatar
you need to remove the valve or hollow it out.
No real diff other than that-
ophdehEEEzy's Avatar
Default Re: (GS-R Civic)
bump!
I have that milky stuff in my catch can and stinks. I want to know what it is too.
Old Dec 14, 2005 | 07:29 PM
GS-R Civic's Avatar
what valve do i need to remove, and why? the valve will but under vaccume just like it is w/o the turbo. nothing really changes so what would need to be hollowed out?
Old Dec 14, 2005 | 08:35 PM
turbotime's Avatar
HERE IS MY IDEAD- WILL THIS WORK OK?!
i thought this was a simple question {sigh}
Old Dec 15, 2005 | 05:09 AM
notoriousB's Avatar
that's how I run my catch can, works fine for me.
Old Dec 15, 2005 | 05:49 AM
Hyaboosta's Avatar
Default Re: (notoriousB)
wow that engine bay is a jungle!
Old Dec 15, 2005 | 06:27 AM
turbotime's Avatar
Default Re: (Hyaboosta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hyaboosta &raquo;</TD></TR><TR><TD CLASS="quote">wow that engine bay is a jungle! </TD></TR></TABLE>
oh the joys of keeping ac/ and ps
Old Dec 15, 2005 | 07:42 AM
Benjithx's Avatar
Open loop is Good!
When Carb Conn blew my ring lands my closed loop system put oil everywhere I didn't want it, Including about a quart in the IC
Old Dec 15, 2005 | 09:16 AM
Default Re: going from closed to open loop pcv- see pics (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">
You have 2 lines going to the catch can and one going to the slashcut. I know one is coming from behind the block, where is the other one coming from? The valve cover has a breather filter
Old Dec 15, 2005 | 10:04 AM
turbotime's Avatar
both are coming from the block- there are fittings from honda which allow you to add more ports on the block for pcv venting- i have two.
BrianV8
Honda CR-V & Element
Aug 8, 2013 08:21 PM
elton_23
Nov 2, 2011 08:01 PM
Cheetah51
Sep 8, 2008 05:27 PM
92HB_HB
May 6, 2005 07:15 PM
Tad
13
Dec 7, 2004 02:46 PM
