Godspeed or Yonaka Intercooler?
I have used 2 Yonaka's thus far, and they have been run on many many higher HP cars around here locally, I'd vouch for them over typical Ebay stuff any day, plus they have a lifetime warranty!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Spend a little more and get a garrett/precision core. There IS a difference...</TD></TR></TABLE>
quick question, is there a big difference on endtanks also, cause i have a precision and i kinda need a back door so i was thinkin about hackin it up and makin my own...?
Well, on that end i don't believe there is a huge difference. The idea at the inlet of the intercooler is to break up the airflow for good distribution through the core. I think hacking up a precision tank to do a back door inlet will work fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Well, on that end i don't believe there is a huge difference. The idea at the inlet of the intercooler is to break up the airflow for good distribution through the core. I think hacking up a precision tank to do a back door inlet will work fine. </TD></TR></TABLE>
What's the difference on the other end??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti »</TD></TR><TR><TD CLASS="quote">
What's the difference on the other end??</TD></TR></TABLE>
The cheap intercoolers don't restrict air flow, causing the air to move to fast and not cool properly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks »</TD></TR><TR><TD CLASS="quote">
The cheap intercoolers don't restrict air flow, causing the air to move to fast and not cool properly. </TD></TR></TABLE>
I understand that part, I was more specifically asking about the end tank design on the cold side
I understand that part, I was more specifically asking about the end tank design on the cold side</TD></TR></TABLE>
Oh sorry... I should be sleeping
We just temp checked two of "equal" size. The Yonaka was larger and the other was the precision 600hp version. Both on H motors, both with low boost doing a 3 gear blast once the car was heated up.
The Yonaka had a 7 degree difference from hot to cold intank and the Precision was 29 degrees difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LVB18Civic »</TD></TR><TR><TD CLASS="quote">Sounds like I should save a little more money and just get a better quality intercooler.</TD></TR></TABLE>
word. your build's only as strong as your weakest link
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing »</TD></TR><TR><TD CLASS="quote">We just temp checked two of "equal" size. The Yonaka was larger and the other was the precision 600hp version. Both on H motors, both with low boost doing a 3 gear blast once the car was heated up.
There IS a difference.</TD></TR></TABLE>
so the yonaka is better or worse?
It's only cooling 7 degrees across the core because it's too open and it carries too much velocity to cool the air.
Similar to pulling a thermostat out of a car completely. It make the water flow so fast that it can't remove any heat from the engine.
Buy a precision.
Buy a precision.
chet
Jul 26, 2007 10:06 PM
