goal 300hp
Old Aug 18, 2009 | 07:03 PM
G-Auto*Hero's Avatar
Default goal 300hp
i have a gsr block and b16 head.
BLOCK-
stock
block guard
HEAD-
blox cams
blox daul springs
blox retainers
skunk2 I.M.
70mm throttle body
aem fuel rail
550rc injectors
255 walbro fuel pump
im going to turbo the car, its going to run a t3/t4 turbo at about 8-10 pounds.
im not wanting to make alot of power, i aiming at 300 any more then that its good you kno.... but you guys think i can make that with out doing it. i know i can hit but well it last?????
Old Aug 18, 2009 | 07:12 PM
project dc2's Avatar
Default Re: goal 300hp
300 it can pretty much run all day probably a 57 trim would do well for your application.
Old Aug 19, 2009 | 11:33 AM
Silva Bullit DC4's Avatar
BLOCK-
stock
block guard
HEAD-
blox cams
blox daul springs
blox retainers
skunk2 I.M.
70mm throttle body
aem fuel rail
550rc injectors
You can reach that power without the items highlighted to save you some money. If you havent already bought them. Alot of people have achieved this number on virtually bone stock motors, granted the motor is healthy (compression & leakdown) and as long as you have a competent tuner, it will last. Mine has been boosted for 2 years (bone stock LS). Good luck, homie.
And as Phil stated, the 57 trim is an excellent choice for that goal, so is the t3/t04e 50 trim.
Old Aug 19, 2009 | 12:16 PM
boosted91crx's Avatar
as stated 300 is cake , heck 300 is cake for a SOHC with only rods and pistons. a b series dont even need that.
Old Aug 20, 2009 | 02:15 PM
Silva Bullit DC4 your right i dont need those mod's to hit 300 hp. but you learn form your mistakes. i had a bone stoke b16 and i wanted to step to the next level. so i got a basic turbo set up. blox iron cast manifold, t70 on 10 psi, 450cc fuel rail & fuel pump, made 297 hp, did like 6 runs and the walls gave out, it looked like katrina hit...... thats why i add a few more parts this time
Old Aug 20, 2009 | 02:33 PM
92redhatch's Avatar
On a 57trim it will take more than 10psi to hit 300whp
Old Aug 20, 2009 | 03:32 PM
DA TeG 90's Avatar
What about a 30r?
Old Aug 20, 2009 | 03:53 PM
1DayIllBFast's Avatar
it will not take more than 10psi. it depends on what turbo kit he has or goes with. the peakboost FTW kit is quoted to make 270whp on 6.5psi. estimated to make 20whp per psi. which i have a bone stock gsr and made 246 at 4psi so he can easily achieve 300whp on 10psi with a 57trim.(i have 57 trim).
Old Aug 20, 2009 | 04:21 PM
92redhatch's Avatar
I don't think it will. Depending what 57 trim he is using it might be possible but I doubt it.
Old Aug 20, 2009 | 09:45 PM
ok man im going to keep this page goin with info. im doing body work " i've been doing body work and custom work sence i've been 14", "and the same with street mechanics" im going to start posting pics soon. im going to use the kit i bought just waitng on the turbo and the manifold. next year im going to aim for 450-500 hp, just waiting for taxes again
Old Aug 21, 2009 | 06:52 AM
solo227's Avatar
redhatch your trippin... With a B18 block and upgraded valvetrain he do 300 very easy...
People do it on competely stock motors... How you figure it cant be done with supporting mods...
Old Aug 21, 2009 | 06:53 AM
solo227's Avatar
A t70 and 450cc injectors is prolly why it blew... LOL
Old Aug 21, 2009 | 07:04 AM
92redhatch's Avatar
Ofcourse 300whp is possible but with a 57yrim and 10psi it's not so likely. Psi doesn't mean anything 300 is 300 even if he needs 15psi. Btw my car made 325whp at 8psi but it's much bigger setup
Old Aug 21, 2009 | 01:08 PM
i should be able to reach 300hp on my stock b18c motor with just 8psi. it is very easy to reach 300whp on just 10psi as long as you have a good manifold and turbo setup. i have the peakboost ftw kit with 57 trim t3/t04e and could reach 300whp easy by 10psi. next couple weeks im going to retune at 8psi and ill post my numbers.
Csewell4
Sep 25, 2013 02:59 PM
itsjdm
Jan 14, 2011 04:04 PM
DVPTeG
May 20, 2007 07:01 PM
yellowhonda88
Feb 6, 2004 12:33 PM
