Gm 3 bar map sensor on OBD2 question
Im trying to install the GM 3 bar map sensor on my car but ran into a little problem. my car is an OBD 2 converted to OBD1 so the wires are different color. I've searched and found nothing for OBD2. my question is how should i connect the wires? Hondata shows a diagram fro OBD1 which are green/whire......White....yellow/red. but my wires are red/yellow.......green/yellow....red/green.. How should i connect this since the color of my wires are different than the one showed on here and hondata. Thanks
I figured it out and I suck at wiring, mines an OBD2 too, I just used the diagram from Hondata and it was easy. I forget which colors went where though, theres only 3 anyway
