girdle question
Old Mar 2, 2007 | 12:24 AM
dansred2000si's Avatar
Default girdle question
okay I have a couple of questions about a girdle. Is it really neccessary for my build, I have a Ls/Vtec turbo build and I am hoping for around 450-500hp. I have stock sleeves on my B18A1, Cp pistons 81.5mm, eagle rods and I am running a GT3076R turbo.
My next question is that my block is already machined and assembled, would this be a problem to remove the already torqued bolts to install the girdle??
Old Mar 2, 2007 | 05:23 AM
DaveF's Avatar
Default Re: girdle question (dansred2000si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dansred2000si &raquo;</TD></TR><TR><TD CLASS="quote">
yes it will be a problem, as installing the girdle/studs may distort the mains. it is recomended to install main studs/girdle, then have it checked and alighn hone/bore as necceessary./
Old Mar 2, 2007 | 07:19 AM
zexxbo's Avatar
Default Re: girdle question (dturbocivic)
yea you need to get it line honed after installing a girdle or main studs, especially if both. usually runs $100+~ for the line hone
you dont need a girdle but it definitely never hurts and you can get the 3 caps for pretty cheap
Old Mar 2, 2007 | 09:06 AM
Boner_Ben's Avatar
Default Re: girdle question (zeimbo)
I wouldnt worry about a girdle on a stock sleeve'd motor. The sleeves will definitly be the first thing to go out of the two.
Old Mar 2, 2007 | 10:21 AM
b18sihatch's Avatar
wouldnt worry about girdle, not now that they are already torqued down
Old Mar 2, 2007 | 10:53 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: girdle question (b18sihatch)
540whp on my b16, was studded but no girdle. no issues.
Old Mar 2, 2007 | 11:58 AM
Default Re: girdle question (boostedcivicsir)
Thanks fellas!!!
ramboPandA
May 13, 2016 01:52 PM
IQ
May 3, 2007 08:39 AM
Race Egr
Jul 23, 2005 08:36 AM
b20vtechatch
Jan 18, 2005 02:11 PM
