gettin REALLY REALLY hot....!!!!
Old Jul 1, 2005 | 08:52 AM
hyabusa hunter's Avatar
Default gettin REALLY REALLY hot....!!!!
hey people!!
this is the story! i have a built h22, 9:1comp, full race setup, SC61, rc550, 3 inch open downpipe, 0.5BAR BOOST
in a JDM 1993 prelude, BUT im also runin a Civic fluidyne RAD (space reasons) 2600cfm 14"fan
anyway, ever since i ran the motor in its been gettin real hot, even at idle! i have changed the thermostat, bleed the system twice, bigger cfm fan on, water pump, water wetter, richined up the AFR. put a carbon bonnet on! cut holes in the front bumper to flo air to the rad!
AND ITS STILL gettin hot!
im running AEM EMS TOO, BUT i live in ENGLAND, NO AEM TUNERS HERE!
THANKS GUYS
Old Jul 1, 2005 | 08:58 AM
spoolinlude's Avatar
I live under a rock
Default Re: gettin REALLY REALLY hot....!!!! (hyabusa hunter)
i had the same problem, turned out that the first time it was the HG, the 2nd time it was the damn rad cap
Old Jul 1, 2005 | 09:01 AM
Default Re: gettin REALLY REALLY hot....!!!! (spoolinlude)
HG.....?
Old Jul 1, 2005 | 09:03 AM
HEAD GASKET I GET IT KNOW! im getting it comp tested tonight! but i cant see how! its all brand new! multi layer cometic!
Old Jul 1, 2005 | 11:10 AM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyabusa hunter &raquo;</TD></TR><TR><TD CLASS="quote"> multi layer cometic!</TD></TR></TABLE>
could be your problem right there......i noticed that 8 out of 10 guys running cometic headgaskets have problems with them.......hope your not one of those 8
Old Jul 1, 2005 | 11:31 AM
tthame1's Avatar
Default Re: gettin REALLY REALLY hot....!!!! (non-VTEC)
Cometic headgaskets are usually used as a quick fix on a messed up motor.
Old Jul 1, 2005 | 11:34 AM
CRX T-Si's Avatar
Default Re: gettin REALLY REALLY hot....!!!! (tthame1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 &raquo;</TD></TR><TR><TD CLASS="quote">Cometic headgaskets are usually used as a quick fix on a messed up motor.</TD></TR></TABLE>
That is ridiculous... so your telling me I have a messed up motor cause I use one?? BS
Old Jul 1, 2005 | 11:47 AM
raceACCORDingly's Avatar
you try water wetter?
Old Jul 1, 2005 | 11:54 AM
alexdog69's Avatar
post some pics.
and stop hatin on cometic there is nothing wrong with cometic
cometic is OG it has been around for years
plenty of sportbike cats use cometic stuff as well as honda
Old Jul 1, 2005 | 12:20 PM
I live under a rock
Default Re: gettin REALLY REALLY hot....!!!! (alexdog69)
totally false...... Many, myself included run cometic gaskets... they're a great gasket, and great of if wanna knock ure CR down a few more ticks
Old Jul 1, 2005 | 12:21 PM
Snail Tuning's Avatar
are you running teh civic or lude radiator cap? there might be a pressure differance between the 2. also you can do the washer trick and put washers between the hood hinges, and the hood, and allow heat to excape through the back.
also wrap the turbo manifold, and downpipe with heat wrap it will cool the engine bay down alot
Old Jul 2, 2005 | 03:47 AM
Honda_Tengoku's Avatar
Default Re: gettin REALLY REALLY hot....!!!! (Snail Tuning)
i am running water wetter! im usung a fluidyne rad and fluidyne rad cap too. im going to do a compression test soon! ill try and get pics of my setup too.
i have just ordered a oil cooler
remember this is in a prelude with a civic rad!
the head gets stupid hot too. im gettin really fed up now, i have a show to go to in august and i still me to fine tune the EMS too
Old Jul 2, 2005 | 04:07 AM
Default Re: gettin REALLY REALLY hot....!!!! (Honda_Tengoku)
that was my best freind answering what he says is right!
Old Jul 2, 2005 | 04:21 AM
f1 vtec's Avatar
THANKS GUYS
know what u mean
Old Jul 2, 2005 | 06:56 AM
angela_itr's Avatar
Default Re: gettin REALLY REALLY hot....!!!! (f1 vtec)
Well if you'd been on Honda Revolutions, you'd have seen that Mase is coming over to the UK at the end of this month to tune some cars!!! But its pretty much full up now unless we get enough to book the dyno for a second day. PM me if you're interested but be quick about it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Tengoku &raquo;</TD></TR><TR><TD CLASS="quote">i have a show to go to in august and i still me to fine tune the EMS too</TD></TR></TABLE>
What show are you talking about, Ultimate Street Car at Pod? I'll keep an eye out for your car then, hoping to run my little turbo ITR there too
Old Jul 2, 2005 | 08:19 AM
bubs's Avatar
You might also want to make sure that your rad. fan is pulling air from the front of the car back instead of pushing toward the radiator.
Old Jul 2, 2005 | 10:14 AM
brandond's Avatar
B A N N E D
Default Re: (bubs)
exactly i had heating issues for a week......i got a h22 in a ferio, i changed my thermostat, didnt fix it, changed my fan didnt fix it, changed all the hoses with the swap didnt do anything, so i bought a new dual core radiator and that fixed my problems, i thought i had a blown headgasket but i wasnt to sure, but i said o what the hell 85 bucks let me go try it out did and im all good ever sice couldnt be happier
Old Jul 5, 2005 | 10:14 AM
Default Re: gettin REALLY REALLY hot....!!!! (angela_itr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by angela_itr &raquo;</TD></TR><TR><TD CLASS="quote">Well if you'd been on Honda Revolutions, you'd have seen that Mase is coming over to the UK at the end of this month to tune some cars!!! But its pretty much full up now unless we get enough to book the dyno for a second day. PM me if you're interested but be quick about it!
What show are you talking about, Ultimate Street Car at Pod? I'll keep an eye out for your car then, hoping to run my little turbo ITR there too </TD></TR></TABLE>
MASE HAS ALREADY been here a couple of mouths ago! is he due to come again?
ill be interested if he is!!!!!! i never had the money then!!
please contact me with details!!!
Old Jul 5, 2005 | 11:29 AM
mike1114's Avatar
A shop can do a pressure test, it involves two color dyes:
IF the dyes mix yell/blue to form green, coolant is leaking past your hg and causing you to overheat. Sometimes you can watch your overflow res and if it starts bubbling a little every now and then that usually means pressure is coming out of the motor (blown HG)
Usually overheating is caused bya bad thermostat or bubbles in the line.
YOU WOULD BE VERY SUPRISED AT HOW LONG IT TAKES TO GET ALL THE BUBBLES OUT OF THE SYSTEM. Bleed it about twice as long as you think it needs to. I found this out the hard way this weekend.
Like half an hour with the heater on.
Pmhearns
May 10, 2015 09:05 AM
Pmhearns
May 1, 2015 12:58 PM
Willy Wiskers
Jun 12, 2014 10:31 AM
EM88
Jul 21, 2009 03:12 AM
skylude23
Mar 3, 2007 02:54 AM
