GEM did it again ...
Old Apr 25, 2003 | 10:12 AM
alpha's Avatar
Default GEM did it again ...
They sent me more parts Thanks for GEM for the vacuum manifold and overbored OEM head gasket. Thanks to Earl for the PWR radiator.
http://photos.yahoo.com/bc/alp...o.com/
Old Apr 25, 2003 | 10:22 AM
93LSivic's Avatar
Default Re: GEM did it again ... (0x64)
I cant believe people are actualy paying money for a piece of ****** aluminum with threaded holes in it. You only paying for the eagle and the GE ingraved into it.
Nice PWR stuff. Im getting ready to buy my second PWR intercooler and a radiator sometime in the future.
Old Apr 25, 2003 | 11:38 AM
alpha's Avatar
Default Re: GEM did it again ... (93LSivic)
It's a nice $30.00 piece of aluminum
Old Apr 25, 2003 | 11:46 AM
Smashback's Avatar
I won't comment on whether or not it's worth $30, but look at it this way - at least it does something!
I bet the people that make the retarded winshield squirter and valvestem cap lights make more money on that crap, and they're useless (and gay!).
Old Apr 25, 2003 | 01:26 PM
genop's Avatar
Default Re: GEM did it again ... (PseudoSilvia)
I'd say its worth $30. It's clean and if you dont have a machine shop in your back yard what the hell else are you going to do? You can always tee a bunch of stuff off, and it will work but sometimes it just doesnt look right and its hard to trouble shoot problems.
Old Apr 25, 2003 | 02:33 PM
inspyral's Avatar
Default Re: GEM did it again ... (genop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genop &raquo;</TD></TR><TR><TD CLASS="quote">I'd say its worth $30. It's clean and if you dont have a machine shop in your back yard what the hell else are you going to do? </TD></TR></TABLE>
http://www.mcmaster.com catalogue pg 159
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Metal and Thermoplastic Manifolds
Build your ideal flow system, starting with these manifolds. Just thread in the fittings you want to use for customized multiple connections to one source. Use plugs (sold separately) to close off outlets not in use. Manifolds have two inlets, one at each end, and two mounting holes. Connections are NPT female (except where noted). BSPP— British Standard Pipe Parallel Thread. BSPT— British Standard Pipe Tapered Thread.
Aluminum— Aluminum alloy 6061 offers high corrosion resistance and protection from contaminants. Withstands working pressures to 3000 psi hydraulic, 1000 psi air. NPT models have a black anodized finish; BSPP and BSPT models have a plain aluminum finish. Temperature range is —10° to +200° F.
Old Apr 26, 2003 | 02:57 AM
blufke's Avatar
Default Re: GEM did it again ... (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">
nice find. what would be a good size to get to run the brake booster line to? 1/4,3/8/ or 1/2. the outlets on the 1/2 one seem kind of large for vac lines to bov,etc.
Old Apr 26, 2003 | 04:50 AM
ricodemus's Avatar
Default Re: GEM did it again ... (blufke)
does anyone have a picture of a vacuum manifold installed? Is it necessary, or does it just make things easier?
Old Apr 26, 2003 | 09:05 AM
inspyral's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blufke &raquo;</TD></TR><TR><TD CLASS="quote">
nice find. what would be a good size to get to run the brake booster line to? 1/4,3/8/ or 1/2. the outlets on the 1/2 one seem kind of large for vac lines to bov,etc.</TD></TR></TABLE>
I ordered the 1/4in-1/8out. Should be here monday or tuesday. I'll see what it looks like when it comes. My total for a 2 inlet/6 outlet manifold, 1 1/4 plug, and 5 1/8 plugs was like $17 before shipping. The aluminum NPT manifolds come anodized black too, w00t
Old Apr 26, 2003 | 01:17 PM
blufke's Avatar
I ordered the 1/4in-1/8out. Should be here monday or tuesday. I'll see what it looks like when it comes. My total for a 2 inlet/6 outlet manifold, 1 1/4 plug, and 5 1/8 plugs was like $17 before shipping. The aluminum NPT manifolds come anodized black too, w00t </TD></TR></TABLE>
whate will you use as the main vac source? the IM?
Modified by blufke at 10:52 PM 4/26/2003
Old Apr 26, 2003 | 03:02 PM
inspyral's Avatar
Modified by blufke at 10:52 PM 4/26/2003</TD></TR></TABLE>
I'll probably use the inlets on the ends of the manifold and run it inline with the brake booster.
TIG WERKS
Welding / Fabrication
39
Nov 11, 2011 07:59 AM
ExVtec
Honda S2000
Feb 24, 2009 12:24 PM
thanh4o8
Sep 4, 2008 11:49 PM
stealth-wrx
Mar 28, 2006 03:58 PM
MisterB
Dec 21, 2002 10:26 AM
