Gear corrected ignition timing
Old Mar 5, 2013 | 05:05 AM
LightningTeg's Avatar
Community Builder
Default Gear corrected ignition timing
Has anyone used gear corrections with ignition timing to lower power in the lower gears for traction?
Car makes 400whp on the waste gate (15lbs) and I don't wanna go smaller because I lose response and its harder to keep boost consistent up top with smaller springs
Old Mar 5, 2013 | 05:19 AM
2000GSRTypeR's Avatar
Default Re: Gear corrected ignition timing
Quick question sir, are you still running a 2 bolt 38mm wastegate sir? If so, do you experience any boost creep with your setup? I know that you have a larger turbo than mine and I was just wondering if you have any problems keeping boost steady with the 2 bolt 38mm wastegate? I am pretty sure what everyone is telling me is correct. I am running little boost and conservative timing on my very efficient turbo and that is why I am experiencing boost creep. I am also running a ram horn manifold and a 2 bolt 38mm wastegate and I am trying to gain knowledge for myself. Thanks in advance and your input is greatly appreciated sir. Sorry for the thread jack sir.
Old Mar 5, 2013 | 05:29 AM
Community Builder
No I dont. I taper my boost controller duty cycle down a bit up top to keep it flat
Old Mar 5, 2013 | 05:31 AM
Thanks for the input sir.
Old Mar 5, 2013 | 06:13 AM
lsturbo33's Avatar
Looks like your injector are maxed out.
Old Mar 5, 2013 | 06:14 AM
Community Builder
A little bit
Old Mar 5, 2013 | 06:40 AM
Muckman's Avatar
Moderator in Chief
Oh that must be nice... lol
I dont understand why you are against boost by gear when you clearly have ebc duty left. You could run a smaller wg spring allowing less boost in lower gears and still run 28psi in the higher gears, just with a higher ebc duty. Its the best of both worlds. Believe me you have alot more boost range left than you realize. I have a 5-30psi range with my setup.
Old Mar 5, 2013 | 07:12 AM
Community Builder
I've tryed it with a 7lbs spring and it hooks in 1st rolling into it and 2nd no problem but the boost comes on slow and builds slow up top as small springs do. I spent days tuning trying to get it as good as it can be. Especially up top it gets very inconsistent
Old Mar 5, 2013 | 07:16 AM
Muckman's Avatar
Moderator in Chief
Make sure the ebc duty is 100% under the boost target. If you are running a static duty to make x boost the entire time, thats not spooling as fast as it can.
Old Mar 5, 2013 | 07:17 AM
Community Builder
Yes fast spool is at 100%. It just doesnt work as well.
Old Mar 5, 2013 | 07:19 AM
Muckman's Avatar
Moderator in Chief
Is the solenoid acting on the top wg port? Or is just on the side wg port and top is open.
Old Mar 5, 2013 | 07:43 AM
Community Builder
Left:
Old Mar 5, 2013 | 07:49 AM
Muckman's Avatar
Moderator in Chief
You can try a 4 port solenoid that will switch all boost reference from the bottom wg port to the top wg port. That will force 100% of the boost pressure to keep the wg shut.
Old Mar 5, 2013 | 08:10 AM
Turbo-LS's Avatar
I didnt use the gear ignition correction to lower power in the lower gears but my tuner pulled timing out in 3-4 gear initially for the first couple passes with the car so we could read plugs and check for detonation with a real load on the motor. Picked up quite a bit of mph when I put the 2 degrees back into it in 3-4 gear. It will definatly reduce power and should help with traction
Old Mar 5, 2013 | 08:47 AM
th3pwn3r's Avatar
Did you ever find out why your car blew up?
Old Mar 5, 2013 | 12:04 PM
Turbo-LS's Avatar
Pretty sure boost spiked to 33 or 34 pounds and just blew it apart. thats 700whp on my turbo and stock sleeves no likey
KillAHonDa
Apr 8, 2008 06:20 AM
Hondoctors
Dec 11, 2006 08:58 AM
VspecSiR
Apr 30, 2004 10:47 PM
pipes
Feb 20, 2004 09:19 AM
TurboTypeR98
Feb 23, 2002 09:04 PM
