GE Vacuum Manifold quick question
Old Mar 5, 2004 | 02:16 PM
  #26
quikB18B's Avatar
Default Re: (DeadLock23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadLock23 &raquo;</TD></TR><TR><TD CLASS="quote">pics would be kool, deadlock23@aol.com is the email.
i just got the 3/8" T the 1/2" hose fits but too lose, so the clamps should solve that i hope.
now I need 1/8" by 1/8" hose barb fittings, but no one has that size, so I'm gonna have to order them from mcmaster-carr....</TD></TR></TABLE>
hmm how loose is that 1/2 line? Last thing you want is that sucker popping off, just make sure you clamp it tight. On those barbed fittings, did you check hardware stores. I've found that hardware stores(ace) always have a ton more stuff than Home depot. I usually find everything i need at Ace hardware.
Btw just emailed the pics to b18flip, and i asked him if he can host them If not I'll email them to you in just a minute .
The steel braided line was in the garage drawer, so I took a hacksaw to it, cut it to the lenght i wanted and taped up the ends.
Old Mar 5, 2004 | 02:28 PM
  #27
mskibbz-T's Avatar
Default Re: (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">I've found that hardware stores(ace) always have a ton more stuff than Home depot. I usually find everything i need at Ace hardware.</TD></TR></TABLE>
I think it really depends on the location, cuz around here Home Depot has a much larger selection of fittings and whatnot
Old Mar 5, 2004 | 02:34 PM
  #28
quikB18B's Avatar
Default Re: (mskibbz-T)
Here are a couple pic of mine, I hope it works this is my first time posting pics.
Old Mar 6, 2004 | 02:26 PM
  #29
vietjdmboi's Avatar
could someone tell me what you used the vacuum manifold for? bov, wastegate, boost gauge, and what else?
Old Mar 6, 2004 | 02:52 PM
  #30
quikB18B's Avatar
Default Re: (vietjdmboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietjdmboi &raquo;</TD></TR><TR><TD CLASS="quote">could someone tell me what you used the vacuum manifold for? bov, wastegate, boost gauge, and what else?</TD></TR></TABLE>
My 4 are
1) Wastegate
2) Bov
3) 3 bar map sensor
4) boost gauge
Old Mar 6, 2004 | 09:44 PM
  #31
Rod.'s Avatar
that green plug that goes by the fuel filter, is that your 3 bar map sensor?
is that just splice into your original wires for the stock one?
Old Mar 6, 2004 | 11:18 PM
  #32
quikB18B's Avatar
Default Re: (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">[img]that green plug that goes by the fuel filter, is that your 3 bar map sensor?
is that just splice into your original wires for the stock one?</TD></TR></TABLE>
Yes that is the 3 bar. There is instructions on hondata's website, but yes you just splice into stock sensor wires and leave the stock one unplugged. This way if you need to run your stock sensor for whatever reason you can just plug it in, and vice versa.
Old Mar 16, 2004 | 10:19 PM
  #33
dfoxengr's Avatar
i have a few extra Tees for the brake line if anyone needs one. 3/8" in size. also have some stainless line extra too. PM me.
Old Mar 17, 2004 | 08:16 AM
  #34
X-Mazda 3 Racer's Avatar
Default Re: (hybridvteceg)
We actually now have a kit that includes a tee and 6 vacuum fittings. The fittings ate the type that do not need hose clamps, so it's an easy splice into the booster line, installation of the tee, and then hook-up to the vacuum manifold. Then the vacuum lines are also supplied for the nominal vacuum line size. It's very easy and costs less than $6.00 Give us a call (909) 592 - 4311 ext. 102. Thanks guys.
Old Mar 19, 2004 | 03:38 AM
  #35
pissedoffsol's Avatar
25 Year Member
Default Re: (GoldenEagleMfg.com)
vince, got any pics? I can't find any proper sized T's at the hardware store....
Old Mar 19, 2004 | 02:57 PM
  #36
Default Re: (pissedoffsol)
This is the perfect compliment to your Golden Eagle vacuum manifold. Comes with everything you need. Cost is about $6.00 or so Give us a call!
Freshdot
Jan 17, 2012 01:18 PM
HT Chaplain
Apr 18, 2006 07:04 AM
BoOsTiN Dc2
Jun 2, 2005 08:57 PM
FwdCivicHatch
May 29, 2004 03:50 PM
integra-modder
Nov 13, 2003 11:41 PM
