Gaskets and flanges absolutely necessary?
Old Apr 13, 2004 | 01:50 PM
MrCivic98's Avatar
Default Gaskets and flanges absolutely necessary?
Is it necessary to run the gaskets in addition to the flanges? for example, on the downpipe....in addition to the flange i welded to the downpipe, do i need the gasket as well? for some of my flanges im having a tough time finding gaskets! tia
Alex
Old Apr 13, 2004 | 01:57 PM
redboost10's Avatar
Default Re: Gaskets and flanges absolutely necessary? (MrCivic98)
if they are surfaced areas you shouldnt have a problem with exhaust leaks. if you do and dont have a gasket for that particular flange then go to a auto store and get some gasket material eventhough i think it might burn up.
Old Apr 13, 2004 | 02:06 PM
b16ahybrid's Avatar
Default Re: Gaskets and flanges absolutely necessary? (tgh99si)
I hope the area has a surface, otherwise there would be no point.
If the surface is true, then you should be able to get by without a gasket, if it's warped then you'll definatly need one.
I've used the high temp gasket maker before and it works for a short time before burning up.
Now i use no gasket between the wg and manifold
Old Apr 13, 2004 | 02:12 PM
redboost10's Avatar
Default Re: Gaskets and flanges absolutely necessary? (b16ahybrid)
yeah, you know what i tried to say about the surface, if its a machined surface is what i meant.
Old Apr 13, 2004 | 03:16 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">yeah, you know what i tried to say about the surface, if its a machined surface is what i meant.</TD></TR></TABLE>
Yeah I know,
inthad
Apr 4, 2008 08:46 AM
jBj
Nov 18, 2005 03:31 PM
doggydog
Jan 20, 2005 07:31 PM
toolowsol
Jan 5, 2005 03:34 PM
vietjdmboi
Sep 23, 2004 06:52 PM
