Garrett GT series turbos
Re: Garrett GT series turbos (Hella_JDM)
From what Geoff said, that is a poor combination of turbo. The turbine wheel is too small for that compressor.
HTH,
Justin
HTH,
Justin
Moderator
Re: Garrett GT series turbos (Justin Olson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson »</TD></TR><TR><TD CLASS="quote">From what Geoff said, that is a poor combination of turbo. The turbine wheel is too small for that compressor.
HTH,
Justin</TD></TR></TABLE>
that "poor" combination only applies to the cylinder heads like a honda uses for efficiency. Otherwise, it's great for 2.0 liter factory motors like the SR20.
HTH,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">damn , why?</TD></TR></TABLE>
Since when are brand new GT series a ''dam, why not a cheap price? '''
Re: Garrett GT series turbos (ben@importparts.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com »</TD></TR><TR><TD CLASS="quote">That turbo costs a little over $2000.00.</TD></TR></TABLE>
http://optionimports.com/impor....html
under 1100
under 1100
Re: Garrett GT series turbos (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 »</TD></TR><TR><TD CLASS="quote">
under 1100</TD></TR></TABLE>
I can meet or beat allof those prices on Garrett turbos! http://www.boostfed.net for contact info. I don;t have all the specifics on the GT2540 turbo yet, but Garrett has come out with soooo many new and innovative turbos lately! Again I was thinking of a GT40R or GT4067R for my set up, the dual BB option would really help with spool.
OG triple OG
Re: Garrett GT series turbos (MidShipCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic »</TD></TR><TR><TD CLASS="quote">
Since when are brand new GT series a ''dam, why not a cheap price? ''' </TD></TR></TABLE>
they are not 2000 dollars buddy , i have a gt series turbo
Re: Garrett GT series turbos (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">
we used it on a 96 mitsubishi eclipse, very disappointed in the results.
Re: Garrett GT series turbos (freakie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakie »</TD></TR><TR><TD CLASS="quote">If this is not a suitable turbo, then what is a better one for low spool with good response?</TD></TR></TABLE>
GT35R
GT35R
Re: Garrett GT series turbos (Full-Race Geoff)
GT2540 is the HKS speced 54mm 76 trim NS111 turbine with a 76mm 46 trim TO4E wheel . HKS more or less admitted its a dog by releasing the GTRS replacement with its I think 52 trim 71mm wheel . ATP (ATP Turbo.com) sells the GT2871 which uses a similar if not identical CHRA . They have just released two more turbos along the same lines as HKS's GT2835's with the 84 and 90 trim turbines (56.6mm) basically cut down GT30 UHP turbines . They are sold with GT28 style exhaust housings with T25/28 footprint in .64AR (84T) and .86AR (90T) .
These last two are about the turbine size upper limit for the GT28 housings with integral gates for "drop in" style fit .
Thanks for the info, I believe that the GT2540 is rated to 400 hp?
Im after something abit bigger than the gt2530/gt2535 as they are spose to be ultra responsive but seem to limit the high end abit.
Anyone think of a better turbo for a street daily driven car that sees circuit once or twice a year?
Why does everyone preach these huge turbos?
Do compressor maps serve no purpose?
I've got no experiance w/ a GT35R on a D series motor, but how can you even get it to spool when it supports like 600hp?
OG triple OG
Re: (Grodzman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grodzman »</TD></TR><TR><TD CLASS="quote">Why does everyone preach these huge turbos?
I've got no experiance w/ a GT35R on a D series motor, but how can you even get it to spool when it supports like 600hp?</TD></TR></TABLE>
sure it supports 600whp , but i wanted a lower boost higher horsepower application . i ran the numbers before i bought it dont worry.
they are not 2000 dollars buddy , i have a gt series turbo</TD></TR></TABLE>
The GT2540 is an HKS turbo and lists for $2400.00.
how much power are you looking for?
the gt28rs+ from atp is a kick *** turbo, we have basicly maxed one out on a built b16 at 371hp, 289tq, full 20psi of boost at 4500 rpms
spoolin turbo s
08-27-2008 10:19 PM
chicken head
10-06-2006 07:08 PM
