Garrett .63 Vs .82 AR ?
Old Mar 9, 2010 | 07:04 AM
attack666's Avatar
Default Garrett .63 Vs .82 AR ?
hey guys,
im currently using Garrett t3 t67 with a .82 housing on my Daily use civic b16.
its pretty laggy until vtec kicks in which i really dont like, since it smokes pretty bad its time to get a new turbo so im getting a garrett 60-1.
QUESTION is: buy 60-1 with a .63 AR or .82 AR?
Looking for more of a street use car than drag, aiming 450 whp with a new setup
whp difference between these 2 AR's is only 25whp which really doesnt matter to me.
Please..share your opinion
Old Mar 9, 2010 | 07:15 AM
TheShodan's Avatar
Moderator
Default Re: Garrett .63 Vs .82 AR ?
That depends upon the exhaust wheel used. The standard exhaust wheel is a stage III and is rather a poor match for the 60-1 wheel, especially if you get one in the T04S .70A/R housing. If you go smaller on the housing with a better exhaust wheel, you'll find a world of difference. A/R housings are only a slight beginning of change in response characteristics. Its the matching of the compressor and exhaust wheels WITH the housings that make a bigger overall difference.
Old Mar 9, 2010 | 08:38 AM
civic-r11's Avatar
Originally Posted by attack666
hey guys,
I have the .63 ar and i good for 500ish..
Old Mar 9, 2010 | 12:18 PM
TheShodan's Avatar
Moderator
with which turbine wheel?
Old Mar 9, 2010 | 02:00 PM
Turbo-LS's Avatar
what are you doing with that t67? id like to buy it if the price is right. im looking to upgrade my compressor
Old Mar 9, 2010 | 02:58 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
are you open to different turbos? i think you can get a better choice than a 60-1 for your hp goals
Old Mar 9, 2010 | 03:02 PM
TheShodan's Avatar
Moderator
^^ Definately.
Old Mar 9, 2010 | 03:11 PM
GEN2 LS's Avatar
Loved
what would you suggest?
Old Mar 9, 2010 | 03:47 PM
attack666's Avatar
TheShodan...What you said is exactly what im thinking of, so what do you think good or bad?
here it is:
http://cheapturbo.stores.yahoo.net/gat3w63ar.html
Turbo-LS:if your willing to come all the way to my country, ill give you the turbo for free lol
ahobbs: sure!! shoot me some names as long as they dont exceed $700
Old Mar 9, 2010 | 06:07 PM
Turbo-LS's Avatar
no idea where that is, im willing to pay shipping and some money for yoru troubles. lmk it would be a great way to upgraed my compressor
Old Mar 9, 2010 | 07:20 PM
TheShodan's Avatar
Moderator
here it is:
Good company. Bad combination, in either housing. For $700, you're better off with the T3/T04e 60 trim than this 60-1 combination. This version uses the Stage III wheel with the T04S I was talking about that was not optimal.
Old Mar 9, 2010 | 11:54 PM
91jdmhatchback's Avatar
I kno wi have seen you post about the 60-1 in the "standard" combination as sold by most shops being not a good combination. Can you explain why you think this?
If you have said this 50 times already, sorry. haha
Old Mar 10, 2010 | 07:41 AM
TheShodan's Avatar
Moderator
Pm'd so you can keep the info for a while
Old Mar 10, 2010 | 07:43 AM
GEN2 LS's Avatar
Loved
can I get a copy too lol!! now I feel like I should sell my turbo.....
Old Mar 10, 2010 | 08:02 AM
TheShodan's Avatar
Moderator
yeah. i gotcha
Old Mar 10, 2010 | 02:02 PM
nowtype's Avatar
Is it too difficult to type "The turbine is too small for the compressor wheel."
It's not that complicated. The turbine wheel is too small for the compressor. As a result, you have a turbine limited turbo. The spool won't be much faster than a stage V wheel because it still has the big 60-1 wheel attached. It won't be able to make as much power because of reversion. Overall, people are not sensible enough to build turbine limited setups.
If you do want to build a turbine limited setup, your exhaust manifold needs to be bigger than normal, it may require a larger wastegate, and your exhaust needs to be larger than you typically would run. This will take care of most of the issues of being turbine limited but it still won't make as much power as a stage V wheel.
Buy a 50 trim standard t3/t04e in "standard configuration". You'll be more than pleased.
Old Mar 10, 2010 | 04:23 PM
civic-r11's Avatar
Good stuff... Now i have to sell my 60-1 .63... Time to find another turbo that is going to work properly.... Honda-tech has great info.. keep it going ..
Old Mar 10, 2010 | 04:55 PM
nowtype's Avatar
Not all 60-1 turbos are turbine limited. A lot of them come with Stage V turbine wheels. In that case, the turbo is a good turbo. It's not as good as the SC61, but it is still a good turbo. SC61 uses a Stage V T3 wheel, but has a GT40r compressor wheel. GT40r comp wheel is a great wheel.
Old Mar 10, 2010 | 05:13 PM
lyncoors's Avatar
dont get a 60-1. look into a 5857. can be had for 785 shipped
Old Mar 10, 2010 | 09:17 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
here it is:
im sorry im just getting back to your post. There are a lot of turbos out there some have already said some
pane93civhb
Mar 18, 2008 05:00 PM
O16581724 5 2 5
Nov 7, 2005 09:02 PM
civicb18c
Sep 27, 2004 05:14 PM
GraphiteAccord
Oct 21, 2003 02:08 PM
B20bTurbo
May 8, 2002 10:11 PM
