b20 turbo question
Old Mar 6, 2010 | 09:25 PM
wallice's Avatar
Default b20 turbo question
I have a 96 midori civic hatch with a jdm b20 swap. i got a b18b1 head i had pnp valve job and new supertech springs i am put on my b20 i also have crower stage 2 cams with vision cam gears. i'd like to know what headgasket i should use a b20 or the b18 gasket. i'm also planning on boosting it with 7lbs. i have the turbo, manifold, dp, fmic, i have 310 rc injectors, fmu, and a missing link for now anyways. i'll upgrade my setup later, i'll be getting a chipped ecu then have it tuned for sure. i'm still in need of ic piping and a bov.
Old Mar 6, 2010 | 09:32 PM
chrisfromsrq's Avatar
Default Re: b20 turbo question
just get a b20 comedic triple layer head gasket
Old Mar 7, 2010 | 06:28 AM
JDMs1eeper's Avatar
auto-zone sells felpro gaskets for the b20 for like $40
Old Mar 7, 2010 | 07:05 PM
wallice's Avatar
yeah i work at advance auto parts, so the felpro gasket is easily at hand, but should i use the one for the b20 or the b18, its a b20 block b18 head. i was gonna go cometic, and would it be the 84mm bore, or the 81mm bore.
Old Mar 10, 2010 | 08:03 PM
wallice's Avatar
well i'm still researching, I still need to know what headgasket I should use. either the one for a b20 or the one for the b18. any help would be great. thanks
Old Mar 10, 2010 | 10:08 PM
Blaze45's Avatar
Brrraaaap!
Run the B20 gasket. The Honda stock 3 layer steel HG is a good piece. If you are still unsure, call whoever did the head work. I don't recommend running the FMU with missing link. Chipping ECU's is too cheap and easy and important to skimp on this part of any turbo setup. You won't regret saving up just a little longer to do it right. Get a new fuel pump with your setup as well. The Walbro 255 can be had for like $80 with the mounting kit. I ran 15lbs (T3/T4) on a B20 for over a year before I sold the setup. With the right tune, these engines make good trq. #s and can be beat on without any issues.
Good luck.
Old Mar 10, 2010 | 10:09 PM
Schister66's Avatar
Man U FTW
The FMU and missing link setup would be fine if this were 1997, but nowadays we have far better cheap options such as Crome. I would highly recommend that in lieu of your current "EMS"
Old Mar 11, 2010 | 02:37 AM
_kiid's Avatar
get at least crome
Old Mar 11, 2010 | 02:56 AM
wallice's Avatar
i already have a walbro 255 pump so i'm good there. and thanks i'll get the b20 gasket. and this setup was only temporary until i can get it tuned
Racer9999
Mar 18, 2014 06:12 PM
slow95sedan
Apr 11, 2003 08:27 PM
Shft@9GSR
Oct 9, 2002 10:25 AM
Ri5e
Feb 28, 2002 10:25 PM
