Gain response from smaller chargepipe?
Old Nov 15, 2003 | 03:32 PM
BoostedD15B7's Avatar
Default Gain response from smaller chargepipe?
My pipe right before the throttle body is a 3" pipe from a Drag kit. If i swap to a smaller pipe, say the size of the rest of the ic pipes, will i gain a good bit more response?
Old Nov 16, 2003 | 12:44 AM
turbopimp's Avatar
Default Re: Gain response from smaller chargepipe? (BoostedD15B7)
The top pipe on a DRAG kit is 2.5", not 3" ... reducing the diameter of the pipe will not result in any notable gains in response. It would probably be cheaper to swap the turbine housing for a .48 ar housing. Response will improve signifigantly, although it may decrease top end a bit depending on your partcular application.
Old Nov 17, 2003 | 03:16 AM
thanks
stillsmokey
Dec 28, 2007 12:37 PM
Desir Performance
Welding / Fabrication
Jun 16, 2007 09:41 PM
flarinpnoi
Sep 22, 2004 06:31 PM
Sprockets
Aug 2, 2004 11:39 PM
Etylorcen
Mar 20, 2002 11:20 AM
